  3. Change text block size, Allegro script and skill
  • Replies 17
  • Subscribers 169
  • Views 31693
skillnewbie
skillnewbie over 17 years ago
hi,
I want to change a text block size (#16). i run a script recording and get this from the *.scr
 setwindow pcb
trapsize 302
define text
setwindow form.textblock
FORM textblock 16 width 0.1000
FORM textblock 16 height 0.1000
FORM textblock 16 line_spacing 0.0200
FORM textblock 16 photoplot_width 0.0100
FORM textblock done
setwindow pcb
just wonder what the FORM means in a script file...it is not a valid command in Allegro
 is it possible to enclose the FORM statements in skill code?
  • DE202408202727
    DE202408202727 over 16 years ago
    Hi Sam,
    Stop the script by using the menu: file ->script ->stop.
    Of course, resetting the text blocks in your library won't help unless those text blocks match your designs. The best method is to reserve and standardise the first 16 (minimum) text blocks across your company. The Cadence defaults might be OK. We use blocks 1, 2 and 3 (customised) for library reference designators (depending on the size of the part) and 17 for silkscreen text.
    I have some Skill that might help do what you want. However, running utilities across an entire library isn't for the faint hearted. If you have parts created in older versions of Allegro you will have to run dbdoctor on those parts before you start- easy if they are in one folder - not so easy otherwise. You should take a backup copy of each library before updating it.
    Good luck, Dave
  • charales
    charales over 16 years ago
    our board text sizes are all the same, I usually start with a previous board file where everything is already set up, makes life simple. When i get the other sites, brd files then the text sizes are different. I'm trying to get them something other than a screen shot of my "text setup". I'm also trying to sync the parts' text blocks with the boards text blocks. Thanks for your response i'll try the script again.
  • rahays
    rahays over 15 years ago
    Dave,
    Are you willing to share your skill code?
    Robert Hays
  • DE202408202727
    DE202408202727 over 15 years ago
    Hi Robert,
    See the attached code. It's just been cobbled together from existing code and I haven't tested any part of it. It can be used to run a function on all dra's in your library. It can't be used without modification as, at least, your own library paths will neet to be used.
    Running dbDoctorAll will bring all your dra's up to the version you are currently running - use with care.
    Note the commented out actionFunction(). This should be used to run whatever command you need to update each symbol.
    Dave
    libraryUpdate.il
  • rahays
    Thanks very much, Dave! BTW how are things in Christchurch? I know that it has been tough.
     Bob
