  3. Change text block size, Allegro script and skill
  • Replies 17
  • Subscribers 169
  • Views 31700
skillnewbie
skillnewbie over 17 years ago
hi,
I want to change a text block size (#16). i run a script recording and get this from the *.scr
 setwindow pcb
trapsize 302
define text
setwindow form.textblock
FORM textblock 16 width 0.1000
FORM textblock 16 height 0.1000
FORM textblock 16 line_spacing 0.0200
FORM textblock 16 photoplot_width 0.0100
FORM textblock done
setwindow pcb
just wonder what the FORM means in a script file...it is not a valid command in Allegro
 is it possible to enclose the FORM statements in skill code?
  • DE202408202727
    DE202408202727 over 15 years ago
    Hi Bob,
    I hope you find the code useful.
    Things are slowly returning to a new normal here in Christchurch. The central business district is still cordoned off as many of the buildings are unstable and need to be demolished. My company is fortunate in that we are on the city outskirts in a relatively unaffected area. Some of my colleagues, friends and family have not been so lucky.
    Regards, Dave
  • N i z e
    N i z e over 14 years ago
    Hm, bad news there! I'm using Orcad PCB 16.2. For some reason the the text blocks of my parts (all currently using block 2 for assembly ref des and block 3 for silkscreen ref des) are assigned seemingly random numbers. Same parts does get same "new numbers" on the same board. But if I start a new board they get a new set... Always block numbers over 5 - so I thought 1-4 might be reserved. If Dave is using 1,2,3, and 17 it can't be the problem. So now I'm just puzzled!!!
     It seems to crucial/obvious to be a program error (?) but I seriously struggle to find out what I'm doing wrong! I anyone has a hit it'll be greatly appreciated ;-D
     Cheers,  Anders
