  3. drawing text with skill function
  • Replies 14
  • Subscribers 168
  • Views 21595
skillnewbie
skillnewbie over 17 years ago
I have been wanting to draw some text in my mcm layout.
as far as i understand, the axlDBCreateText function will require user to allocate
a textblock for the text to be created. but I want to make the text independent of
any textblock...
i thought of converting the text to lines (after it is created) but it seems not possible,
and (correct me if i am wrong) the axlGPRDrwText can only draw the text on the forms.
anyone can help? thanks in advance =)
  • kerchunk
    kerchunk over 17 years ago
     Allegro comes standard with a number of textblocks predefined -  you could use one of them without much fear of a user messing things up. Or set them exactly how you want them within a .ilinit file.
    HTH,
    Chris Walters
    local Cadence guru
  • DE202408202727
    DE202408202727 over 17 years ago
    See attached.
    Cheers, Dave
    drawTextFunction.zip
  • skillnewbie
    Hi eDave,
    Thanks for the solution and it works finely.
  • skillnewbie
    hi eDave,
    Is it possible to add in an attribute of "Rotation" of the text in the function?
    it can be quite difficult to spin it after the text is created as it involves the selection
    of Lines.
  • DE202408202727
    Have you tried using the "angle" parameter?
