  3. drawing text with skill function
  • Replies 14
  • Subscribers 168
  • Views 21596
skillnewbie
skillnewbie over 17 years ago
I have been wanting to draw some text in my mcm layout.
as far as i understand, the axlDBCreateText function will require user to allocate
a textblock for the text to be created. but I want to make the text independent of
any textblock...
i thought of converting the text to lines (after it is created) but it seems not possible,
and (correct me if i am wrong) the axlGPRDrwText can only draw the text on the forms.
anyone can help? thanks in advance =)
  • aCraig
    aCraig over 17 years ago
    Another option is to put the lines representing the text in a group. Then you can easily move, rotate, mirror the lines as one object.
    -Craig
  • skillnewbie
    hi eDave,
    yupz, the angle option works. thanks~
    I didnt go through your coding carefully initially, so missed this part.
    hi Craig,
    yupz. thanks for the suggestion. because the text string is a variable so it could be
    quite difficult to select with skill's selecting functions.
    newbie
  • soufiane
    soufiane over 16 years ago
    Hi
    I liked your (skill file), how can use it.
    thank you.
  • DE202408202727
    DE202408202727 over 16 years ago
    The function is designed to be called from other Skill code.
    The following function call will draw the text "test" at -30:-30 on ETCH/TOP with a character height 4.0, width 3.0, spacing and line width 0.5 (in the default units):
    PUBLIC_drawText("test", '(-30 -30), "ETCH/TOP", 4.0, 3.0, 1.0, 0.5)
    Dave
  • soufiane
    Thank you for your answer
