  3. drawing text with skill function
  • Replies 14
  • Subscribers 168
  • Views 21602
skillnewbie
skillnewbie over 17 years ago
I have been wanting to draw some text in my mcm layout.
as far as i understand, the axlDBCreateText function will require user to allocate
a textblock for the text to be created. but I want to make the text independent of
any textblock...
i thought of converting the text to lines (after it is created) but it seems not possible,
and (correct me if i am wrong) the axlGPRDrwText can only draw the text on the forms.
anyone can help? thanks in advance =)
  • PCB Librarian
    PCB Librarian over 16 years ago
    I have a skill where to view the max & min component height (the skill will showing the max value only). I want to modify the skill where to have the output as MAX_HEIGHT = 'value' height (I need to have the text "MAX_HEIGHT=" before the max height value). Anybody can help me on this?
    show_height.il
  • DE202408202727
    DE202408202727 over 16 years ago
    Use something like:
    sprintf(myVar "MAX_HEIGHT = %2.3f", value)
    Dave
  • PCB Librarian
    Hi Dave,
    Thanks for u'r fast feedback. From this coding, it will print for MAX HEIGHT & MIN HEIGHT (it use sprintf(s_prop "%s", prop)) & will print the value only. I'm still new in CDS skill and I'm not very sure where is the correct place to make sure the output to have text with 'MAX_HEIGHT' & "MIN_HEIGHT" before the value by using u'r aabove advice:-(
    if( l_props!=nil
    then ;check to make sure there are attached properties.
    foreach( prop l_props ;step through each property
    if( s_prop == max
    then
    if( length(l_props)>2 ;Are both min and max defined?
    then
    max_ht=cadr(l_props->?)
    else
    max_ht=car(l_props->?)
    );endif length
    y=y1+max_offset
    if( shape->layer== place_top
    then
    axlDBCreateText( max_ht x:y txt_orient_top t_layer_top shape)
    else
    axlDBCreateText( max_ht x:y txt_orient_bot t_layer_bot shape)
    );endif layer
    else
    if( s_prop == min
    then
    shape_layer=shape->layer
    min_ht=car(l_props->?)
    y=y1+min_offset
    if( shape->layer == place_top
    then
    axlDBCreateText( min_ht x:y txt_orient_top t_layer_top shape)
    else
    axlDBCreateText( min_ht x:y txt_orient_bot t_layer_bot shape)
    );endif layer
    );end if prop min
    );end if prop max
    );end foreach
    );end if
    );end foreach
  • aCraig
    aCraig over 16 years ago
    Place a print statement where you find the height with the text for that height. So when you find MAX_HEIGHT do:
    axlMsgPut("MAX_HEIGHT = %s" s_prop)
    Then do the same for minimum height.
    - Craig
