  3. FORM designer for Skill
  • Replies 22
  • Subscribers 166
  • Views 33187
vramanan
vramanan over 17 years ago
Hi Guys
I was wondering is there is any gui development tools for SKILL, It is very tedious to type the FORM file in BNF format and try to debug it
 I searched in the web to no avail, if anyone knows a tool which will let you design the SKILL forms graphically like the forms designer and output the form file please let me know
 mean while I found out some tools that might be of interest
I used to write automated scripts using Autoit it has a free form designer called KODA
www.autoitscript.com/.../formdesign.html
this will save the form file as a KXF file and which is a XML file and can output an autoit script which is similar to visual basic
If anyone write a script/tool convet the xml to BNF or autoit to BNF that would be great.
for example The output of the koda will look like
$Form1 = GUICreate("Board Template Editor", 752, 561, -1363, 199)
$Tab1 = GUICtrlCreateTab(16, 24, 713, 521)
GUICtrlSetResizing(-1, $GUI_DOCKWIDTH+$GUI_DOCKHEIGHT)
$TabSheet1 = GUICtrlCreateTabItem("Board Details")
$Group1 = GUICtrlCreateGroup("Board Details Input", 32, 64, 681, 449)
$Input1 = GUICtrlCreateInput("Input1", 152, 112, 121, 21)
$Button1 = GUICtrlCreateButton("Button1", 64, 448, 75, 25)
$Checkbox1 = GUICtrlCreateCheckbox("Checkbox1", 128, 384, 97, 17)
$Checkbox2 = GUICtrlCreateCheckbox("Checkbox2", 280, 384, 97, 17)
$Checkbox3 = GUICtrlCreateCheckbox("Checkbox3", 424, 384, 97, 17)
$Button2 = GUICtrlCreateButton("Button2", 160, 448, 75, 25)
$Label1 = GUICtrlCreateLabel("Label1", 80, 120, 36, 17)
$Label2 = GUICtrlCreateLabel("Label2", 80, 152, 36, 17)
$Input2 = GUICtrlCreateInput("Input2", 152, 144, 121, 21)
GUICtrlCreateGroup("", -99, -99, 1, 1)
In BNF it should look like
FORM
FIXED
PORT 80 55
HEADER "Board Template Editor"
TILE
TABSET "Board Details"
FLOC 16 24
TSSIZE 713 521
TAB "Pack_Select"
 Any help/leads on this regard will be much appreciated
  • Ejlersen
    Ejlersen over 17 years ago
    Hi
    Found that the math::round package was not installed properly, so now it works.
    Found the following issues with tpages.il after translation
    - line 181 has 14 added at the front, which means the skill program won't load.
    Besides from this, there's also some issue displaying the form file due to incorrect syntax.
    However, if I run it on my first own form created in Koda it works very well. I'm sure this is something that has a future.
    Best regards
    Ole
  • vramanan
     Hi Ole
    Edit the perl file and comment out line 196, it will work fine
    I am working on a new version
    these are the things I have done
    1. Optimized the code (500 lines less than the original)
    2. Added Support for Grids, Progress Bar, Track Bar, TreeView, ListView
    3. Optimized the locations and Size of the fields, it looks like the original XML file
    4. It will include the Value field for the Inputs
    These are the things I will be working on
    1. A Documentation explaining the entire process, FAQ, rational etc..
    2. Support to include GRID-Column/Row logic(auto generate Skill code)
    3.  A possible GUI and auto-rename .kxf to .xml
    4. A installation package which will auto install all the needed files neatly
    I will release the new version when time permits
    Regards
    Venkata
  • Ejlersen
    Hi Venkata
    I think it works very well already.
    I was actually thinking about making a description of this for a technical newsletter that we send out 1-3 times a month refering Danish users to get the perl script from this thread. Would that be ok with you.
    You can see our technical newsletters (unfortunately in Danish) on http://www.nordcad.dk/dk/teknik__service/e-service/
    Please let me know if this would be ok with you. You could email me directly at oe(at)nordcad.dk. I would offcourse give you the credit for the tool.
    Best regards
    Ole
  • vramanan
    vramanan over 16 years ago
    Hi Guys
    For what it is worth, I have done the following
    1. updated the script with lots of bug fixes
    2. Added a GUI interface
    3. Added Help and info
    4. created an installation package with standalone executable plus the source
    Now you don't need to rename the KODA form .kxf to .xml, the gui will do the trick, no need to have the .inc in the same directory
    no need to have perl installed, this is a standalone tool with all the help you need
    Now you can get all the things by downloading the setup_xml2bnf.exe at
    http://github.com/xml2bnf/xml2bnf
     Now this thing can rest a little bit without bugging me
    Enjoy and share atleast one utility you create with this to the community
    Appreciate your feedback and comments
    Regards
    Venkata
  • oldmouldy
    oldmouldy over 16 years ago
    Not too sure if anyone else has tried this but I cannot get it to fire up.
    I am using Vista 32 and 64 which might explain something BUT I have the Perl from AllState, added the XML::XPath, Math::Round, Tk 804 packages. The GUI does not start from the ".exe" and when I try to run the perl source through "perl xml2bnf.pl" at a command prompt I get a message about not being able to locate "Tk/NumEntry.pm", this presumably needs another Perl package but I can't seem to find a likely candidate listed in the available packages in PPM. I guess that the "Tk::ROText" might be missing as well.
    *Update*
    OK, found that the NumEntry required is part of Tk::GBARR, got closer BUT "incvalue" is no longer an option for NumEntry, have to "hash" the "incvalue"s out to get the UI to run, but now the edits cannot be incremented by anything other than 1, the default "incvalue"
    This might be flying but I wouldn't fancy actually taking off!
