  3. FORM designer for Skill
  • Replies 22
  • Subscribers 166
  • Views 33190
vramanan
vramanan over 17 years ago
Hi Guys
I was wondering is there is any gui development tools for SKILL, It is very tedious to type the FORM file in BNF format and try to debug it
 I searched in the web to no avail, if anyone knows a tool which will let you design the SKILL forms graphically like the forms designer and output the form file please let me know
 mean while I found out some tools that might be of interest
I used to write automated scripts using Autoit it has a free form designer called KODA
www.autoitscript.com/.../formdesign.html
this will save the form file as a KXF file and which is a XML file and can output an autoit script which is similar to visual basic
If anyone write a script/tool convet the xml to BNF or autoit to BNF that would be great.
for example The output of the koda will look like
$Form1 = GUICreate("Board Template Editor", 752, 561, -1363, 199)
$Tab1 = GUICtrlCreateTab(16, 24, 713, 521)
GUICtrlSetResizing(-1, $GUI_DOCKWIDTH+$GUI_DOCKHEIGHT)
$TabSheet1 = GUICtrlCreateTabItem("Board Details")
$Group1 = GUICtrlCreateGroup("Board Details Input", 32, 64, 681, 449)
$Input1 = GUICtrlCreateInput("Input1", 152, 112, 121, 21)
$Button1 = GUICtrlCreateButton("Button1", 64, 448, 75, 25)
$Checkbox1 = GUICtrlCreateCheckbox("Checkbox1", 128, 384, 97, 17)
$Checkbox2 = GUICtrlCreateCheckbox("Checkbox2", 280, 384, 97, 17)
$Checkbox3 = GUICtrlCreateCheckbox("Checkbox3", 424, 384, 97, 17)
$Button2 = GUICtrlCreateButton("Button2", 160, 448, 75, 25)
$Label1 = GUICtrlCreateLabel("Label1", 80, 120, 36, 17)
$Label2 = GUICtrlCreateLabel("Label2", 80, 152, 36, 17)
$Input2 = GUICtrlCreateInput("Input2", 152, 144, 121, 21)
GUICtrlCreateGroup("", -99, -99, 1, 1)
In BNF it should look like
FORM
FIXED
PORT 80 55
HEADER "Board Template Editor"
TILE
TABSET "Board Details"
FLOC 16 24
TSSIZE 713 521
TAB "Pack_Select"
 Any help/leads on this regard will be much appreciated
  • vramanan
    vramanan over 16 years ago
     Hi
     download this Numentry from
    http://search.cpan.org/~mmarco/clickTk-4.013/lib/ctkNumEntry.pm
    and replace it on perl\site\tk
    and also copy ctkBitmapto perl\site and perl\site\tk http://search.cpan.org/~mmarco/clickTk-4.013/lib/ctkBitmap.pm
    The standalone exe is complaining that  it needs another dll, i added to the github
    http://github.com/xml2bnf/xml2bnf
    the dll name is libexpat.dll
    For Tk:ROText you have to install it
    For this exact reason i created the standalone exe from PP but still it is not perfect
    I repacked it again
    just download the standalone exe (xml2bnf.exe) again from github this should work
    http://github.com/xml2bnf/xml2bnf/raw/master/xml2bnf.exe
    Regards
    Venkata
  • vramanan
     Hi Guys
    this is the issue with perl modules, the Tk::NumEntry won't allow any other increment other than 1
    where as ctk widget will allow it,
    I have updated all the exe and setup on github, this should work now
    regards
    venkata
  • oldmouldy
    oldmouldy over 16 years ago
    Many thanks for looking at this, this new version seems to be working correctly now.
  • eDaNoy
    eDaNoy over 15 years ago
    vramanan, thanks for the GUI its a big help,
  • BingSun
    BingSun over 14 years ago
    Tks Venkata.U do the big help
