  3. "set telskill"does not work in the Orcad 16.2 PCB editor...
  • Views 1677
"set telskill"does not work in the Orcad 16.2 PCB editor?
YangFan
YangFan over 17 years ago
Hello,all:
I found "set telskill" does not work in the Orcad 16.2 PCB editor,there is no skill box open!
Command > set telskill
Command > skill
E- Command not found: skill
How to get the skill box?
  • oldmouldy
    oldmouldy over 17 years ago
    The OrCAD and Allegro L PCB Editor tool levels do not support running the skill environment, they can load and run SKILL routines that have been pre-written at start-up but loading and debugging of SKILL routines at the command line are not supported, You need at least a Performance Option license to author and debug SKILL routines.
