  3. creaing private functions
  • Views 14603
Ejlersen
Ejlersen over 16 years ago
Hi
If I split my skill code up into defun/procedures/functions these are visible and could potentially have the same name in another skill program. Is there a way to make such a defun/procedure/function private to just that one skill program?
Please adwice if you have some suggestions.
Best regards
Ole
  • aCraig
    aCraig over 16 years ago
    Ole,
    I don't believe you can. In the Skill Language User Guide there is a section discussing Naming Convention to avoid conflicts with Cadence functions. And Cadence simply uses a "_" at the beginning of a function to indicate private. I typically use my initials or company ticker symbol in uppercase followed by "_". But that's not a 100% guarantee.
    -Craig
  • Ejlersen
    Hi Craig
    Thanks for your answer. Thats what I thought - all my programs are called ns_xxxxx - but the same defun can be used across skill programs.
    Best regards
    Ole
