  3. Same Net Via Spacing?
  • Subscribers 166
  • Views 21492
Allan M
Allan M over 16 years ago
Dear Cadence Community,
I am using OrCAD PCB Designer 16.3.  I have been asked by my PCB mfg to keep my "min spacing to all Via pads, blind, buried and through, .009". "  Not quite sure what he means but it looks as if vias can't be closer together than 0.009", regardless of net assignment.
So, how do I set up my Constraint Manager to produce DRC errors for vias which are too close together even if they are on the same net?  I can't seem to figure this out.
For example, lets say, in the Same Net Spacing Spreadsheet, I set the Via to Via spacing to 2mm.  Why don't I get a DRC error if I place two vias on the same net too close together?
An earlier thread talked about the Analysis Mode dialog.  I looked through it and found that the "Same Net Spacing" DRC mode was not checked for Vias.  I checked it, exited the Constraint Manager and did a DRC check.  Still no DRC error.
Maybe I am just misunderstanding something.  Can anybody help me clear up this misunderstanding?
Cheers,
Allan
  • ArturoArias
    ArturoArias over 16 years ago
    Hi Allan, I'm not sure if you're activating the checking of these violations. Please go to "Setup>Constraints>Modes..." and select the "Spacing Modes" tab; expand "Vias" tree and be sure it has activated the ones you set in the Constraint Manager. Then in "Same Net Spacing Modes" tab, enable the same vias you've set... I would eneable all in both tabs. Voilà, it should show you the DRC's where the spacing is not 0.009". Hope this is helpful. Regards. Arturo
  • Rik Lee
    Rik Lee over 16 years ago
     There are three things that must be set in order to detect a same net DRC.
    1. A value set for the spacing in the worksheet. I believe you have this set
    2. The Same net DRC check enabled in the Same Net Spacing Modes dialog. I believe you have that set as well.
    3. There is an Options worksheet in the Same Net Spacing workbook. A value of TRUE for the Enable DRC By-Layer check must be set for the Same Net Spacing Constraint set you want to check.
    ~Rik
  • pterm
    pterm over 6 years ago
    By default (it seems), the PCB editor adds ThruVias to the BB vias list.  This allows vias to overlap.
    Try using Setup>B/B Via Definitions>Define B/B Vias and remove ThruVia pad stacks from this list.
