  3. Testprep...how to control distance from testvia to component...
  • Replies 11
  • Subscribers 166
  • Views 22704
Testprep...how to control distance from testvia to component pad.
steveO
steveO over 16 years ago
I've tried to set the distance from a smd pin to a smd testvia but don't get the desired results. The distance ends up being via to smd pin which is smaller. How can i accomplish this without putting in a no-probe area around the pins? Thanks.
  • obwise
    obwise over 5 years ago in reply to steveO
    Hey @steve0 have you found a solution to you situation yet?  I'm actually looking for a report that can tell me which test points are too close to components based off the CM clearance rules.  Is there an interface that can do this.  Sometimes some tps get missed as far as sticking with the constraints and I want to see which ones those are.
