  3. A weird result about the function "IF"
  • Views 1446
stillfish
stillfish over 15 years ago
I run the following line in skill command line :
Skill > if((7.15>7.1+0.05) println("#") println("$"))
and then it shows
nil
It seems the condition of "IF' was passed, which is not what i expected.
And even i change the syntax to if(greaterp(7.15 7.1+0.05) println("#") println("$"))
it still shows
nil
Can anyone explain about this result, thanks!
  • PCB George
    PCB George over 15 years ago
    Try something like
    if ( ( 7.15 > 7.1+0.05 )
      then
        println(“#”)
      else
        println(“$”)
    George
  • fxffxf
    fxffxf over 15 years ago
    Computers are digital machines while floating point math is analog. A floating point number cannot always be represented exactly in a digital representation. This means when you do any logical comparison of floating point numbers, you must either use an Epsilon value or force a rounding operation.
    See the web reference in the documentation for axlGeoEqual.
  • stillfish
    Thanks for your reply.
    I decide to use the rounding function before comparing two floating value, and it works fine.
