  3. temporary object highlighting
  • Views 17135
SkilSiao
SkilSiao over 14 years ago
My function requires user to select an object (like a shape or via) for some process,
usual process is we set the find filter first, then use axlEnterPoint(?prompt ...) function
to prompt user to select an object. but the axlEnterPoint does NOT highlight (temporarily)
the object which the Cursor points to.
Like "show element" command, we set the find panel, then when we place the cursor to an object
which is satisfied with the find panel setting, the object will be highlighted.
is there any function to achieve this (the temp highlighting of the object under the cursor)?
  • DE202408202727
    DE202408202727 over 14 years ago
    It is possible but only with some programming effort - use axlCursorGet within a loop.
  • SkilSiao
    Hi dave,  i am trying to make a loop of:
    while(axlSelect() ... axlCursorGet() ) ;
    but it seems the object(s) are also not highlighted with axlSelect()
    i am also thinking of a while(axlCursorGet()  ... ) but that will make
    an endless loop and Allegro eventually hangs.
    it is not a must anyway, i shall explore this further again.
    Thanks for the hint.
  • EvanShultz
    EvanShultz over 10 years ago
    Does anybody have example code? Maybe it's easier since 2011? It does seem possible but a bit complex, and a known-good solution from a guru like eDave would be nice rather than trying to figure it out myself.
  • DE202408202727
    DE202408202727 over 10 years ago
    Yes. It is easier than it was. Use axlHighlightObject and axlDehighlightObject.
    Here's a routine that demonstrates:
    defun( DE_selectbyType (findTypes)
    let((popup, oldSelSet, selTypes, objs, selSet)
    popup = axlUIPopupDefine(nil, '(
    ("Done", "axlFinishEnterFun()")
    ("Oops" "selSet = cdr(selSet)")
    ("Cancel", "selSet = nil, axlCancelEnterFun()")
    axlUIPopupSet(popup)
    unless(listp(findTypes), findTypes = list(findTypes))
    oldSelSet = list(axlGetSelSet(), axlGetFindFilter(nil), axlGetFindFilter(t))
    axlClearSelSet()
    selTypes = cons("noall", findTypes)
    axlSetFindFilter(?enabled cons("nameform", selTypes), ?onButtons selTypes)
    while(axlSelect(?prompt sprintf(nil, "Select %s. (RMB for options)", axlPPrint(buildString(findTypes, ", "))))
    objs = axlGetSelSet()
    axlHighlightObject(objs, t)
    selSet = lconc(selSet, objs)
    axlSetFindFilter(?enabled cons("noall", cadr(oldSelSet)) ?onButtons cons("noall", caddr(oldSelSet)))
    axlSingleSelectObject(car(oldSelSet))
    selSet = unique(car(selSet))
    axlDehighlightObject(selSet, t)
    axlUICmdPopupSet(nil)
    selSet
    ;load("DE_selectbyType.il"), DE_selectbyType("shapes")
  • EvanShultz
    Slick! Thanks Dave!
