  3. Help me with Via parameter !
  • Replies 12
  • Views 20899
luanvn81
luanvn81 over 14 years ago
 Hi everyone!
I have a skill file ( download from internet), I'm researching it but there are something I don't understand, so I hope evertone can help me. And here is it:
axlCmdRegister( "myCompanyViaReport" `myCompanyViaReport)
(defun myCompanyViaReport ()
; Find all of the vias in the design
allViasInDesign=list()
originalVisible=axlVisibleGet()
designName = axlCurrentDesign()
axlVisibleDesign(t)
axlShell("redisplay")
axlSetFindFilter(?enabled '(noall vias) ?onButtons '(noall vias))
allViasInDesign=axlGetSelSet(axlAddSelectAll())
axlClearSelSet()
; Open a file to work on
if(length(allViasInDesign)==0
then
axlUIConfirm("No vias in this design. Please try another design.")
else
writeOutFile = outfile("./TBL-DesignViaReport.csv" "w")
fprintf(writeOutFile strcat("Design Via Report for " designName "\n\n"))
fprintf(writeOutFile "Via Location,Via Net Name,Padstack Name,Via Start
Layer,Via End Layer\n")
; Output data for each via to the file
foreach(via allViasInDesign
viaLocation = sprintf(nil "%L:%L" car(via->xy) cadr(via->xy))
fprintf(writeOutFile strcat(viaLocation ","))
fprintf(writeOutFile strcat(via->net->name ","))
fprintf(writeOutFile strcat(via->name ","))
fprintf(writeOutFile strcat(car(via->startEnd) ","))
fprintf(writeOutFile strcat(cadr(via->startEnd) "\n"))
);end foreach via allViasInDesign
; Close the file and wrap up
fprintf(writeOutFile "END OF FILE")
close(writeOutFile)
axlVisibleSet(originalVisible)
axlUIConfirm( "Report has been generated in your working directory." )
; This next line launches Excel and displays the report
axlHttp("TBL-DesignViaReport.csv")
);end if length(allViasInDesign)==0
);end defun myCompanyViaReport
- How can I know paramerter of Vias such as ViaLocation, via net name, via name, via start layer, end layer in order to make this:
I'm using Allegro 16.3 and it seem can't run with BB via.
Tks!
Luanvn81
  • luanvn81
    Hi Dave!
    Thank for yours reply! you are really a good man, I really admire you.Your code is perfect, I only fix  the letter "sublass" by "subclass" in your code and then it works now, it has written out  file "tempfile.tmp", but in command line in allegro appear error" :
    E- *Error* fprintf/sprintf: format spec. incompatible with data - "Format is '%s%-30s %-20s %-30s', argument #2 is nil"
    Tks.  I'm so sorry for disturance you.
    Luan.
  • DE202408202727
    DE202408202727 over 14 years ago
    Thanks for finding my typo! I think the "L" key on my keyboard might be stuck.
    This code should be better but look for improvements. It's only meant as a guide.
    subclasses = '("VP24", "VP22")
    foreach(subclass, subclasses
    viaList = stringToSymbol(strcat("viaList_", subclass))
    set(viaList, nil)
    axlVisibleDesign(nil)
    axlVisibleLayer(strcat("via class/", subclass) t)
    ;axlShell("redisplay")
    axlVisibleUpdate(t)
    allViasInSubclass = axlGetSelSet(axlAddSelectAll())
    axlClearSelSet()
    foreach(via allViasInSubclass
    netname = via ->net ->name
    when(netname && (nindex(netname "HC") || nindex(netname "LC") || nindex(netname "GND"))
    set(viaList, cons(via, eval(viaList)))
    );end foreach via
    );end foreach subclass
    writeOutFile = outfile( "TempFile.tmp" ) ; open write tmp file
    fprintf(writeOutFile, "                                 %-49s", strcat("Layer ", subclass))
    fprintf(writeOutFile, "\n\n")
    fprintf(writeOutFile, "----------------------------------------------------------------------------------")
    fprintf(writeOutFile, "  Vianame                      Via location         Via net name                  ")
    while(exists(subclass, subclasses, eval(stringToSymbol(strcat("viaList_", subclass))))
    line = ""
    via = car(eval(viaList))
    if(via then
    sprintf(viaLocation "%L:%L" car(via ->xy) cadr(via ->xy))
    sprintf(line, "%s%-30s %-20s %-30s", line, via ->name, viaLocation, via ->net ->name)
    else
    sprintf(line, "%82s", line)
    set(viaList, cdr(eval(viaList)))
    fprintf(writeOutFile, "%s\n", line)
    close(writeOutFile)
  • luanvn81
     Hi ! thank for your code. It works OK, I have changed writting out method in order to apply for many layers.
      Now. Can you show me other problem ?
    I'm testing a code, but there something I don't know. Here the code.
      axlCmdRegister( "Reportvia" `Reportvia)
    (defun Reportvia ()
    if(isFile("netlist.txt") then
    netlist = list()
    netlist = nil
    inPort = infile( "netlist.txt" )
    when( inPort
    while( gets( nextline inPort )
    netlist = cons(concat(nextline),netlist)
    );end while
    close( inPort )
    netlist=reverse(netlist)
    );end when
    else
    axlUIConfirm( "File netlist.txt can't be found!")
    exit()
    );end if
          foreach(netname, netlist
            netlist->netname = 10    ; property of each net name =10
          );end foreach
        writeOutFile = outfile( "./Via_report.txt" )
           fprintf(writeOutFile, "%s %d\n", get_pname(concat(netname)), netlist->netname)
           );end foreach
          close(writeOutFile)
    );end defun
    1/ Can you show me  if the netlist.txt file isn't exist ==> ;E- *Error* eval: unbound variable - netlist. How can I resolve it?
    2/ In order to print netname out, is there any others way to get name of net.
    3/ the result of my code : (via_report.txt), - and the result don't like as I wish.
    D1_HC1_4
     10
    netname 10
    10 10
    D1_HC2
     10
    D1_HC3
     10
    D1_HC4
     10
    D1_HC5 10
     ===> please show me where is wrong?how can I fix it?
    (my netlist is:
    D1_HC1_4
    D1_HC2
    D1_HC3
    D1_HC4
    D1_HC5
    tks.
    Luan.
  • DE202408202727
    Hi Luan,
    exit doesn't behave as you are expecting. You can't use it to "exit" your code like this.
    Your code is very confusing. Is this what you are trying to do?
    axlCmdRegister( "Reportvia" 'Reportvia)
    defun( Reportvia ()
    netlist = nil
    when( inPort
    nextline = car(parseString(nextline, "\n"))
    netlist = cons(concat(nextline), netlist)
    );end while
    close( inPort )
    netlist = reverse(netlist)
    netname ->count = 10
    );end foreach
    fprintf(writeOutFile, "%s %d\n", get_pname(netname), netname ->count)
    );end foreach
    close(writeOutFile)
    );end when
    else
    );end if
    );end defun
  • luanvn81
     Hi Dave! Actually I want to count number of vias for each net (in netlist.txt)  layer by layer in brd data, and this is whole my code:
    (defun Reportvia ()
    subclasses = '("VP24, VP23, VP22" )
    ;========Check & get input file==========
    netlist=list()
    netlist=nil
    when( inPort
    netlist=cons(concat(nextline),netlist)
    );end while
    close( inPort )
    ;==========format what to do for each subclass ==========================
    ;========== Get vias layer by layer & save in a list=====================
    viaList = concat("viaList_", subclass)
    set(viaList, nil)
    axlVisibleUpdate(t)
    axlClearSelSet()
    ;===== Create listnetslayer & set list's elements = netlist's element====
    netlistlayer = concat("netlist_", subclass)
    set(netlistlayer,eval(netlist))
    ;========== Caculating number of vias each net in layer =================
    foreach(netname, netlistlayer
       sumvias = setof(via, allViasInSubclass, via->net->name = get_pname(netname))
       netname->count = length(sumvias)
    );end foreach netname
    ;========== Write out file========
        writeOutFile = outfile( "./Via_by_layer_and_netname_report.txt" ) ; open write tmp file
    ;========== Format outfile =======
       ; ##########NOT FORMAT YET###########
    close(writeOutFile)
    );end when
    ;======= Review begin status======
    else
    );enf if netlist.txt
    );end defun
    ?: =====>  E- *Error* eval: undefined function - D1_HC1_4 , can you show me how to fix this error.
    Thanks alot.
    Luan.
