  3. Help me with Via parameter !
  • Replies 12
  • Views 20905
luanvn81
luanvn81 over 14 years ago
 Hi everyone!
I have a skill file ( download from internet), I'm researching it but there are something I don't understand, so I hope evertone can help me. And here is it:
axlCmdRegister( "myCompanyViaReport" `myCompanyViaReport)
(defun myCompanyViaReport ()
; Find all of the vias in the design
allViasInDesign=list()
originalVisible=axlVisibleGet()
designName = axlCurrentDesign()
axlVisibleDesign(t)
axlShell("redisplay")
axlSetFindFilter(?enabled '(noall vias) ?onButtons '(noall vias))
allViasInDesign=axlGetSelSet(axlAddSelectAll())
axlClearSelSet()
; Open a file to work on
if(length(allViasInDesign)==0
then
axlUIConfirm("No vias in this design. Please try another design.")
else
writeOutFile = outfile("./TBL-DesignViaReport.csv" "w")
fprintf(writeOutFile strcat("Design Via Report for " designName "\n\n"))
fprintf(writeOutFile "Via Location,Via Net Name,Padstack Name,Via Start
Layer,Via End Layer\n")
; Output data for each via to the file
foreach(via allViasInDesign
viaLocation = sprintf(nil "%L:%L" car(via->xy) cadr(via->xy))
fprintf(writeOutFile strcat(viaLocation ","))
fprintf(writeOutFile strcat(via->net->name ","))
fprintf(writeOutFile strcat(via->name ","))
fprintf(writeOutFile strcat(car(via->startEnd) ","))
fprintf(writeOutFile strcat(cadr(via->startEnd) "\n"))
);end foreach via allViasInDesign
; Close the file and wrap up
fprintf(writeOutFile "END OF FILE")
close(writeOutFile)
axlVisibleSet(originalVisible)
axlUIConfirm( "Report has been generated in your working directory." )
; This next line launches Excel and displays the report
axlHttp("TBL-DesignViaReport.csv")
);end if length(allViasInDesign)==0
);end defun myCompanyViaReport
- How can I know paramerter of Vias such as ViaLocation, via net name, via name, via start layer, end layer in order to make this:
I'm using Allegro 16.3 and it seem can't run with BB via.
Tks!
Luanvn81
  • DE202408202727
    DE202408202727 over 14 years ago
    Hi Luan,
    There must be easier was to do this but here are some corrections:
     defun( Reportvia ()
    subclasses = '("VP24, VP23, VP22" )
    ;========Check & get input file==========
    if(isFile("netlist.txt") then
    ;netlist=list(); unnecessary
    netlist=nil
    inPort = infile( "netlist.txt" )
    when( inPort
    while( gets( nextline inPort )
    nextline = car(parseString(nextline, "\n"))
    netlist=cons(concat(nextline), netlist)
    );end while
    close( inPort )
    netlist = reverse(netlist)
    ;==========format what to do for each subclass ==========================
    foreach(subclass, subclasses
    ;========== Get vias layer by layer & save in a list=====================
    viaList = concat("viaList_", subclass)
    set(viaList, nil)
    axlVisibleDesign(nil)
    axlVisibleLayer(strcat("via class/", subclass) t)
    axlVisibleUpdate(t)
    allViasInSubclass = axlGetSelSet(axlAddSelectAll())
    axlClearSelSet()
    ;===== Create listnetslayer & set list's elements = netlist's element====
    netlistlayer = concat("netlist_", subclass)
    set(netlistlayer, netlist)
    ;========== Caculating number of vias each net in layer =================
    foreach(netname, eval(netlistlayer)
      ;sumvias = setof(via, allViasInSubclass, via->net->name = get_pname(netname))
      sumvias = setof(via, allViasInSubclass, via ->net ->name == get_pname(netname))
      netname ->count = length(sumvias)
    );end foreach netname
    );end foreach subclass
    ;========== Write out file========
    writeOutFile = outfile( "./Via_by_layer_and_netname_report.txt" ) ; open write tmp file
    ;========== Format outfile =======
    ; ##########NOT FORMAT YET###########
    close(writeOutFile)
    );end when
    ;======= Review begin status======
    else
    axlUIConfirm( "File netlist.txt can't be found!")
    );enf if netlist.txt
    );end defun
  • luanvn81
     Hi! I sorry for disturbing  you once more, but I have found an error that i can't fix it. The code works but it's seem  not correctly.
    the result is as below:
     Net_name         Layer_Vp24          Layer_VP22
     D1_HC1_12            593                        593
     D1_HC13_14            51                        51
    Instead of:
    ( exactly result)
     D1_HC1_12            604                       593
     D1_HC13_14            501                       51
     ==>I think the number of via of Vp24 are replaced by the number via of VP22, but i didn't find error in the agorithm.
    Here're whole code:
     axlCmdRegister( "Reportvia" `Reportvia)
    (defun Reportvia ()
    ;========Declare Subclasses==========
    subclasses = '( "VP24", "VP22")
    ;subclasses = '("VP24", "VP23" , "VP22" ,"VP21" ,"VP20" ,"VP19" ,"VP18" ,"VP17" ,"VP16" ,"VP15" ,"VP14" ,"VP13" ,"VP12" ,"VP11",
    ;               "VP10" ,"VP9" ,"VP8" ,"VP7" ,"VP6" ,"VP5" ,"VP4" ,"VP3" ,"VP2" ,"AL1-v" ,"AL2-V - JUNCTION" ,"BL-v" ,"CL-v" )
    ;========Check input file==========
    netlist=nil
    when( inPort
    nextline = car(parseString(nextline, " "))      ;check if there're blank
    netlist=cons(concat(nextline),netlist)
    );end while
    close( inPort )
    netlist=reverse(netlist)
    ;==========format what to do for each layer =============================
    ;========== Get vias by layer ===========================================
    axlVisibleUpdate(t)
    axlClearSelSet()
    set(netlistlayer,netlist)
       sumvias = setof(via, allViasInSubclass, via->net->name == get_pname(netname))
       netname->count = length(sumvias)
    ;========== Write out file===============================================
        writeOutFile = outfile( "./Via_layer_report.csv" )
    ;========== Format Intro for outfile ====================================
    intro="Net_name,"
        sprintf(intro,strcat(intro, " Layer_", subclass,"," ))
    );end foreach
    fprintf(writeOutFile, "%s\n\n",intro)
    ;===========Format output data for outfile =============================
    ;while(exists... : check if all list of suppied layer # nil then print out...
    while(exists(subclass, subclasses, eval(concat("netlist_", subclass)))
    foreach(net, netlist
    line = ""
           netname = car(eval(netlistlayer))
           sprintf(line, "%-30s, %-6d",line, netname->count)
           set(netlistlayer, cdr(eval(netlistlayer)))
        fprintf(writeOutFile, "%s %s\n", net, line)
    );end foreach net of netlist
    );end while
    close(writeOutFile)
    axlUIConfirm( "Report has been generated in your working directory!" )
    axlHttp("Via_layer_report.csv")
    );end when
    else
    ;);enf if netlist.txt
    );end defun
    Tks.
    Luan.
