  3. Help me with Via parameter !
  • Replies 12
  • Views 20897
luanvn81
luanvn81 over 14 years ago
 Hi everyone!
I have a skill file ( download from internet), I'm researching it but there are something I don't understand, so I hope evertone can help me. And here is it:
axlCmdRegister( "myCompanyViaReport" `myCompanyViaReport)
(defun myCompanyViaReport ()
; Find all of the vias in the design
allViasInDesign=list()
originalVisible=axlVisibleGet()
designName = axlCurrentDesign()
axlVisibleDesign(t)
axlShell("redisplay")
axlSetFindFilter(?enabled '(noall vias) ?onButtons '(noall vias))
allViasInDesign=axlGetSelSet(axlAddSelectAll())
axlClearSelSet()
; Open a file to work on
if(length(allViasInDesign)==0
then
axlUIConfirm("No vias in this design. Please try another design.")
else
writeOutFile = outfile("./TBL-DesignViaReport.csv" "w")
fprintf(writeOutFile strcat("Design Via Report for " designName "\n\n"))
fprintf(writeOutFile "Via Location,Via Net Name,Padstack Name,Via Start
Layer,Via End Layer\n")
; Output data for each via to the file
foreach(via allViasInDesign
viaLocation = sprintf(nil "%L:%L" car(via->xy) cadr(via->xy))
fprintf(writeOutFile strcat(viaLocation ","))
fprintf(writeOutFile strcat(via->net->name ","))
fprintf(writeOutFile strcat(via->name ","))
fprintf(writeOutFile strcat(car(via->startEnd) ","))
fprintf(writeOutFile strcat(cadr(via->startEnd) "\n"))
);end foreach via allViasInDesign
; Close the file and wrap up
fprintf(writeOutFile "END OF FILE")
close(writeOutFile)
axlVisibleSet(originalVisible)
axlUIConfirm( "Report has been generated in your working directory." )
; This next line launches Excel and displays the report
axlHttp("TBL-DesignViaReport.csv")
);end if length(allViasInDesign)==0
);end defun myCompanyViaReport
- How can I know paramerter of Vias such as ViaLocation, via net name, via name, via start layer, end layer in order to make this:
I'm using Allegro 16.3 and it seem can't run with BB via.
Tks!
Luanvn81
  • DE202408202727
    DE202408202727 over 14 years ago
    I tested the code. It works OK. I get a report in my working directory.
  • luanvn81
     Hi!
    Thank for your test!
    I have tested in 4 layer board and using through via, it's OK.  but I test with another brd and  got following error:
    E- *Error* strcat: argument #1 should be either a string or a symbol (type template = "S") - nil  and I found that one via have dummy net.So Skill file got error.
      By the way, can you explain to me some things in this Skill file:
    1/ I have changed  "axlVisibleDesign(t)" into "axlVisibleDesign(nil)" and add line  "axlVisibleLayer("etch/top" t) but program can't get via on top layer and warning "No vias in this design. Please try another design". How can I get via on top layer?
    2/  How the mark "->"  & "," in line    fprintf(writeOutFile strcat(via->net->name ",")) can be understand ?
    3/ How can I know Via properties in this skill file  in order to print to my file [Ex :fprintf(writeOutFile strcat(via->net->name ",")) ]
       Base on  Via's property  when "show element" via???
     I'm sorry , but I'm trying to learn skill myself.
    Tks.
    Luan.
  • DE202408202727
    Hi Luan,
    1/ Turn on layer "VIA CLASS/TOP"
    2/ I suggest you read the Skill Language User Manual. "The arrow ( -> ) operator gives you a simple way of indirectly accessing properties stored on a symbol's property list". The comma (",") is just printing the comma into the output file
    fprintf(writeOutFile strcat(via->net->name ",")) would be better written as fprintf(writeOutFile strcat(via->net->name || "DummyNet" ","))
    3/ To find all properties of a via, type via ->?? (assuming "via" is the dbid of the via you wish to know the properties of).
    I suggest that you read the available manuals. Learning Skill will be difficult without some background reading or training.
    Dave
  • luanvn81
     Hi Dave!
    Thank you for your reply. I will  read the manuals clearly as your advice.
    Can you show me one problem more?
    I wanna count via layerVP24 and Vp22 and my  code skill like below:
    axlVisibleLayer("via class/VP24" t)
    axlClearSelSet()
    writeOutFile = outfile( "TempFile.tmp" ) ; open write tmp file
    netname=via->net->name
    if(nindex(netname "HC")!=nil then
    fprintf(writeOutFile strcat(via->net->name "\n"))
    else
    if(nindex(netname "LC")!=nil then
    ;fprintf(writeOutFile strcat("Top" " layer" ","))
    else
    if(nindex(netname "GND")!=nil then
    );end HC
    );end LC
    );end GND
    );end foreach
    axlVisibleLayer("via class/VP22" t)
    axlClearSelSet()
    else
    else
    );end HC
    );end LC
    );end GND
    );end foreach
    my problem is:
    How can I write out via list of VP22 in another collumn(as below)
                    Layer Vp24        Layer Vp22
      Vianame    Via location   Via net name                         Vianame    Via location   Via net name
       xxxxx           xxxxxx             xxxxxx                          xxxxx           xxxxxx             xxxxxx
     Tks.
    Luan.
  • DE202408202727
    Hopefully this code will get you started:
    subclasses = '("VP24", "VP22")
    foreach(subclass, subclasses
    viaList = stringToSymbol(strcat("viaList_", subclass))
    set(viaList, nil)
    axlVisibleLayer(strcat("via class/", subclass) t)
    ;axlShell("redisplay")
    axlVisibleUpdate(t)
    allViasInSubclass = axlGetSelSet(axlAddSelectAll())
    axlClearSelSet()
    foreach(via allViasInSubclass
    netname = via ->net ->name
    when(netname && (nindex(netname "HC") || nindex(netname "LC") || nindex(netname "GND"))
    set(viaList, cons(via, eval(viaList)))
    );end foreach via
    );end foreach subclass
    foreach(sublass, subclasses
    fprintf(writeOutFile, "                                 %-49s", strcat("Layer ", sublass))
    fprintf(writeOutFile, "\n\n")
    fprintf(writeOutFile, "----------------------------------------------------------------------------------")
    fprintf(writeOutFile, "  Vianame                      Via location         Via net name                  ")
    while(exists(sublass, subclasses, eval(stringToSymbol(strcat("viaList_", subclass))))
    line = ""
    via = car(eval(viaList))
    viaLocation = sprintf(nil "%L:%L" car(via ->xy) cadr(via ->xy))
    sprintf(line, "%s%-30s %-20s %-30s", line, via ->name, viaLocation, via ->net ->name)
    set(viaList, cdr(eval(viaList)))
    fprintf(writeOutFile, "%s\n", line)
    close(writeOutFile)
