  3. Clear silkscreen from pins in Allegro Package
  • State Suggested Answer
  • Replies 110
  • Answers 2
  • Subscribers 177
  • Views 120519
chads108
chads108 over 14 years ago
 Does anyone have some SKILL code that will clear silkscreen lines back x distance from pins, either as a group or individually?  I want to use this during footprint building.  Currently I have to use delete and cut to remove pieces of lines that run through pads.
  • DE202408202727
    DE202408202727 over 14 years ago +3 suggested
    See attached. It's a context file in the meantime. Load it by using the commands: In Skill (or allegro.ilinit): loadContext("EDAVE_clearPinSilk.cxt") axlCmdRegister("clear pin silk" 'EDAVE_clearPinSilk…
  • DE202408202727
    DE202408202727 over 4 years ago in reply to PK1234 +2
    community.cadence.com/.../3343.EDAVE_5F00_clearPinSilk.zip Hopefully the attached revision has sorted the problems
  • oldmouldy
    oldmouldy over 14 years ago +1
    Surely, when designing the symbol, you don't draw the silkscreen over the pins anyway??
  • DE202408202727
    0 DE202408202727 over 10 years ago
    What he said.
    Let me know if you still have a problem.
  • PaulLap
    0 PaulLap over 9 years ago
    Hi Dave,
    I'd like to thank you for all the code you've submitted over the years.
    I'm having an issue with the CleatPinSilk routine.
    You say if you enter "nil" for any of the values it prompts the user, I get this error when I try the nil value
    Command > clear pin silk 0.3 nil
    E- *Error* greaterp: can't handle (10.5 > nil)
    Paul
  • DE202408202727
    0 DE202408202727 over 9 years ago
    Hi Paul. Thanks for the endorsement.
    Nil is not an valid value for the fields. Try 0.0.
    I guess I could modify the code to more elegantly warn of incorrect entries if it's a continual problem for anyone?
  • PaulLap
    Hi Dave,
    Thanks for the clarification. Don't change anything for me, I was reading pervious comments and wondered why it wasn't working.
    Paul
  • PaulLap
    Dave,
    Have you been able to compile a version for 17.2?
    Paul
