  3. Clear silkscreen from pins in Allegro Package
  • State Suggested Answer
  • Replies 110
  • Answers 2
  • Subscribers 177
  • Views 120513
chads108
chads108 over 14 years ago
 Does anyone have some SKILL code that will clear silkscreen lines back x distance from pins, either as a group or individually?  I want to use this during footprint building.  Currently I have to use delete and cut to remove pieces of lines that run through pads.
  • DE202408202727
    DE202408202727 over 14 years ago +3 suggested
    See attached. It's a context file in the meantime. Load it by using the commands: In Skill (or allegro.ilinit): loadContext("EDAVE_clearPinSilk.cxt") axlCmdRegister("clear pin silk" 'EDAVE_clearPinSilk…
  • DE202408202727
    DE202408202727 over 4 years ago in reply to PK1234 +2
    community.cadence.com/.../3343.EDAVE_5F00_clearPinSilk.zip Hopefully the attached revision has sorted the problems
  • oldmouldy
    oldmouldy over 14 years ago +1
    Surely, when designing the symbol, you don't draw the silkscreen over the pins anyway??
  • B Bruekers
    0 B Bruekers over 10 years ago
    Hi Dave,
    do you have also a 64bit compiled version of this util? (for a 17.2 installation)
    Thanks!
    Bram
  • DE202408202727
    0 DE202408202727 over 10 years ago
    Hi Bram, Not yet sorry. I hope to have a 17.2 license from Cadence within a couple of weeks.
  • GalaxyEleven2
    0 GalaxyEleven2 over 10 years ago
    I Have a some problem..
    I Hope I can find solve here..
    ______________________
    Lampu Surya
    Lampu Tenaga Surya
    Lampu Taman Tenaga Surya
  • tmd63
    0 tmd63 over 10 years ago
    Hi Dave,
    I got an example of your autosilk utils .il file but it doesnt appear to work on SPB16.6.
    I keep getting an error message
    Command> skill load "D:\Cadence\SPB_16.6\tools\SKILL33.00\context\autosilkUtils.il"
    E-
    E- load "D:\Cadence\SPB_16.6\tools\SKILL33.00\context\autosilkUtils.il"
    E-        ^
    E- PARSER WARNING at line 1 column 68 of file *string*
    W- *WARNING* (Parser): character found after backslash is not meaningful - D:\Cadence\SPB_16.6\tools\SKILL33.00\context\autosilkUtils.il
    This repeats a number of times but refuses to run. Do you have an updated version for SPB16.6?
  • B Bruekers
    You need to use "/" in a path inside SKILL code.
    So try: load "D:/Cadence/SPB_16.6/tools/SKILL33.00/context/autosilkUtils.il"
