  3. Clear silkscreen from pins in Allegro Package
  • State Suggested Answer
  • Replies 110
  • Answers 2
  • Subscribers 177
  • Views 120507
chads108
chads108 over 14 years ago
 Does anyone have some SKILL code that will clear silkscreen lines back x distance from pins, either as a group or individually?  I want to use this during footprint building.  Currently I have to use delete and cut to remove pieces of lines that run through pads.
  • DE202408202727
    DE202408202727 over 14 years ago +3 suggested
    See attached. It's a context file in the meantime. Load it by using the commands: In Skill (or allegro.ilinit): loadContext("EDAVE_clearPinSilk.cxt") axlCmdRegister("clear pin silk" 'EDAVE_clearPinSilk…
  • DE202408202727
    DE202408202727 over 4 years ago in reply to PK1234 +2
    community.cadence.com/.../3343.EDAVE_5F00_clearPinSilk.zip Hopefully the attached revision has sorted the problems
  • oldmouldy
    oldmouldy over 14 years ago +1
    Surely, when designing the symbol, you don't draw the silkscreen over the pins anyway??
  • prasisvg
    0 prasisvg over 11 years ago
    Dear Dave,
    Sorry I did not know that the attachment were missing.
    As a matter of fact I have not followed your instructions properly that is why the Error Occurred. Now it is just working Fine and Smooth.
    Thanks For your response.
    I am not sure that this the correct thread to ask this question I believe this make sense. I have a task it is to create a Dotted outline line in bottom silk layer for through hole
    components (Reference for Soldering the leads ).
    Tried to use the Dotted lines but the tool did not let me to have it in silk layer(Subclass).
    Now I have written a code for reading the line,arc,circle segments from Top silk layer then draw them in Bottom silk layer. But I will have to cut those lines evenly.
    Please find the below code and help me to finish my task.
    CODE:
    foreach(line   get_lines_arc_circle
      when(line->layer == "PACKAGE GEOMETRY/SILKSCREEN_TOP"
      foreach(seg  line->segments
      if((seg->objType=="arc") then
      radius = seg->radius
      if((radius>radi) then
      startEnd = seg->startEnd
      start    = nthelem(1 startEnd)
      end      = nthelem(2 startEnd)
      start.x  = nthelem(1 start)
      start.y  = nthelem(2 start)
      end.x    = nthelem(1 end)
      end.y    = nthelem(2 end)
      mid = axlGeoArcCenterRadius(start.x:start.y end.x:end.y radius)
     (axlDBCreatePath
     (axlPathArcCenter
     (axlPathStart (list start.x:start.y)) 0.1524 end.x:end.y t mid) "PACKAGE GEOMETRY/SILKSCREEN_BOTTOM")
     if((seg->isCircle) then
     radiu = seg->radius
     if((radiu>radi) then
     co=seg->xy
     axlDBCreateCircle( list(co radiu), 0.1524, "PACKAGE GEOMETRY/SILKSCREEN_BOTTOM")
     if(!(seg->isCircle) then
     if(!(seg->objType=="arc") then
    if(seg->objType=="line" then
     send = seg->startEnd
     start = nthelem(1 send)
     end   = nthelem(2 send)
     po1=list(start.x start.y)
     po2=list(end.x end.y)
     po3=list(po1 po2)
     disx=axlDistance(start.x:start.y,end.x:end.y)
     midline=axlMidPointLine(list(start.x:start.y end.x:end.y))
     axlDBCreateLine(po3 0.1524 "PACKAGE GEOMETRY/SILKSCREEN_BOTTOM")
    Appreciate your response.
    Prasi
  • DE202408202727
    0 DE202408202727 over 11 years ago
    It would have been better to start a new thread.
    Attached is some code that might help you.https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/prasi.zip
  • prasisvg
    Dear Dave,
    Thank you very  much.
    Really Appreciate your response.
    Code is really cool and it is a good learning for me.
    Now I feel better to write a skill with some advanced math functions.
    Thanks and Regards,
    Prasi
  • gaydance
    0 gaydance over 10 years ago
    Hi Dave, I am using the version 16.6 and have loaded your code EDAVE_clearPinSilk.cxt. But when I want to run it I write "clear pin silk" and get the error "unbound variable - pin". Could you please help me to get it working. Thanks very much in advance
  • DE202408202727
    0 DE202408202727 over 10 years ago
    You should type that command in the command line not in a Skill window.
