  3. Clear silkscreen from pins in Allegro Package
  • State Suggested Answer
  • Replies 110
  • Answers 2
  • Subscribers 177
  • Views 120501
chads108
chads108 over 14 years ago
 Does anyone have some SKILL code that will clear silkscreen lines back x distance from pins, either as a group or individually?  I want to use this during footprint building.  Currently I have to use delete and cut to remove pieces of lines that run through pads.
  • DE202408202727
    DE202408202727 over 14 years ago +3 suggested
    See attached. It's a context file in the meantime. Load it by using the commands: In Skill (or allegro.ilinit): loadContext("EDAVE_clearPinSilk.cxt") axlCmdRegister("clear pin silk" 'EDAVE_clearPinSilk…
  • DE202408202727
    DE202408202727 over 4 years ago in reply to PK1234 +2
    community.cadence.com/.../3343.EDAVE_5F00_clearPinSilk.zip Hopefully the attached revision has sorted the problems
  • oldmouldy
    oldmouldy over 14 years ago +1
    Surely, when designing the symbol, you don't draw the silkscreen over the pins anyway??
  • ojhdanoy
    0 ojhdanoy over 11 years ago
    Hum that is strange because all my filled shapes are trimmed as well (we also use filled shapes for orientation and pin 1 markers). I thought I had the latest version of your code but maybe I'm using an old version.
    BTW here is the command I use "clear pin silk 0.125 0.0".
    Olivier
  • DE202408202727
    0 DE202408202727 over 11 years ago
    Oops. I was thinking of another utility. I'll update the code and give an option to ignore shapes.It's currently compiled for 16.5. Do you use 16.5 or 16.6?
  • ojhdanoy
    Thanks Dave! We're using 16.6. Olivier
  • DE202408202727
    See attached for the 16.6 version (should solve Prasi's problem too).
    Add an extra parameter "t" as the third option to prevent filled shapes from being trimmed. ie.  "clear pin silk 0.125 0.0 t"
    Cheers,
    Dave
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/EDAVE_5F00_clearPinSilk.1.4.16.6.zip
  • ojhdanoy
    Thanks Dave! It's working just fine.
    Olivier
