  3. Clear silkscreen from pins in Allegro Package
  • State Suggested Answer
  • Replies 110
  • Answers 2
  • Subscribers 177
  • Views 120495
chads108
chads108 over 14 years ago
 Does anyone have some SKILL code that will clear silkscreen lines back x distance from pins, either as a group or individually?  I want to use this during footprint building.  Currently I have to use delete and cut to remove pieces of lines that run through pads.
  • DE202408202727
    DE202408202727 over 14 years ago +3 suggested
    See attached. It's a context file in the meantime. Load it by using the commands: In Skill (or allegro.ilinit): loadContext("EDAVE_clearPinSilk.cxt") axlCmdRegister("clear pin silk" 'EDAVE_clearPinSilk…
  • DE202408202727
    DE202408202727 over 4 years ago in reply to PK1234 +2
    community.cadence.com/.../3343.EDAVE_5F00_clearPinSilk.zip Hopefully the attached revision has sorted the problems
  • oldmouldy
    oldmouldy over 14 years ago +1
    Surely, when designing the symbol, you don't draw the silkscreen over the pins anyway??
  • girish
    0 girish over 14 years ago
     Thanks edave.Working fine
    GK
  • prasisvg
    0 prasisvg over 11 years ago
    Dear DAve,
    I have tried to use the .cxt file from my local path.D:
    It shows me an SYNTAX error. Please help me to fix this.
    Kindly refer the below shot.
    prasi
  • DE202408202727
    0 DE202408202727 over 11 years ago
    Please re-post or copy and paste the error. I can't see your screenshot.
  • ojhdanoy
    0 ojhdanoy over 11 years ago
    Dave,
    Is there an option to only trim silkscreen lines and leave silkscreen shapes as is?
    Olivier
  • DE202408202727
    That's what it does. For that reason I prefer to use filled shapes for orientation and pin one markers.
