  3. Clear silkscreen from pins in Allegro Package
  • State Suggested Answer
  • Replies 110
  • Answers 2
  • Subscribers 177
  • Views 120489
chads108
chads108 over 14 years ago
 Does anyone have some SKILL code that will clear silkscreen lines back x distance from pins, either as a group or individually?  I want to use this during footprint building.  Currently I have to use delete and cut to remove pieces of lines that run through pads.
  • DE202408202727
    DE202408202727 over 14 years ago +3 suggested
    See attached. It's a context file in the meantime. Load it by using the commands: In Skill (or allegro.ilinit): loadContext("EDAVE_clearPinSilk.cxt") axlCmdRegister("clear pin silk" 'EDAVE_clearPinSilk…
  • DE202408202727
    DE202408202727 over 4 years ago in reply to PK1234 +2
    community.cadence.com/.../3343.EDAVE_5F00_clearPinSilk.zip Hopefully the attached revision has sorted the problems
  • oldmouldy
    oldmouldy over 14 years ago +1
    Surely, when designing the symbol, you don't draw the silkscreen over the pins anyway??
  • DE202408202727
    0 DE202408202727 over 14 years ago
    16.01. Really!?
    See attached
    EDAVE_clearPinSilk1601.zip
  • girish
    0 girish over 14 years ago
     Thanks for the feedback, still facing problem , screen shot attached
    GK
  • DE202408202727
    Rename the context file to EDAVE_clearPinSilk.cxt
  • girish
    Thank You very much edave, its working .
    Could you help me on “EDAVE_assemblyToClearPinSilk.cxt “  skill file too ,this also providing same error when I run it on 16.01v
    GK
  • DE202408202727
    See attached.
    EDAVE_assemblyToClearPinSilk.1601.zip
