  3. Clear silkscreen from pins in Allegro Package
  • State Suggested Answer
  • Replies 110
  • Answers 2
  • Subscribers 177
  • Views 120483
chads108
chads108 over 14 years ago
 Does anyone have some SKILL code that will clear silkscreen lines back x distance from pins, either as a group or individually?  I want to use this during footprint building.  Currently I have to use delete and cut to remove pieces of lines that run through pads.
  • DE202408202727
    DE202408202727 over 14 years ago +3 suggested
    See attached. It's a context file in the meantime. Load it by using the commands: In Skill (or allegro.ilinit): loadContext("EDAVE_clearPinSilk.cxt") axlCmdRegister("clear pin silk" 'EDAVE_clearPinSilk…
  • DE202408202727
    DE202408202727 over 4 years ago in reply to PK1234 +2
    community.cadence.com/.../3343.EDAVE_5F00_clearPinSilk.zip Hopefully the attached revision has sorted the problems
  • oldmouldy
    oldmouldy over 14 years ago +1
    Surely, when designing the symbol, you don't draw the silkscreen over the pins anyway??
  • soori3
    0 soori3 over 14 years ago
    Hello Dave,
    Thanks for your help, it works perfect,... :)
    Actually in our Libray the footprints will have the silkscreen same as assembly line so i have one script which will copy the assembly top and change to silkscreen top (and also line width from 0.1 mm to 0.254 mm) and after placing the silkscreen exactly on the assembly i am using your Context file which clears the silkscreen on pads, can i link this script file and context file or can we have a code in Context file itself which will copy the assembly to silkscreen first (and also line width from 0.1 mm to 0.254 mm)and places the silkscreen exactly on the assembly and runs the silkscreen cleanup next....?
     Please suggest...
    Thanks & Regards,
    Suresh
  • DE202408202727
    0 DE202408202727 over 14 years ago
    Hi Suresh,
    See attached.
    Use: axlCmdRegister("assembly lines to silk" 'EDAVE_assemblyToClearPinSilk ?cmdType "interactive")
    You can vary the parameters by adding them to the end of the command in the order: silk width, clearance, minimum length. If you enter "nil" for any these the user will be prompted for a value. eg:
    assembly lines to silk 0.25 nil
    Dave
    EDAVE_assemblyToClearPinSilk.zip
  • soori3
    Wow.... it works great :)
    Thanks for your help in clearing all my issues.. really now my task was soo easy...
    Suresh Annam
  • girish
    0 girish over 14 years ago
    Good one.
     In cadence silkscreen utility it was copying to manufacture Autosilk & losing linking connection with the symbol !
    This works great .Thanks
    GK
  • girish
    Thanks EDave for sharing useful skill file which I was looking for .
    I have made a script file  where I recorded the command  with my custom values as you suggested & executing the skill routine by calling script file, it works great  & saves my time during FP creation
    its executing perfectly in Orcad PCB editor 16.3 , but facing problem while linking to
    allegro16.01 ver ,skill file not loading getting below error
     E- *Error* loadContext: incompatible version - "EDAVE_clearPinSilk.cxt"
    Any suggestions  please.
    GK
