  3. Clear silkscreen from pins in Allegro Package
  • State Suggested Answer
  • Replies 110
  • Answers 2
  • Subscribers 177
  • Views 120476
chads108
chads108 over 14 years ago
 Does anyone have some SKILL code that will clear silkscreen lines back x distance from pins, either as a group or individually?  I want to use this during footprint building.  Currently I have to use delete and cut to remove pieces of lines that run through pads.
  • DE202408202727
    DE202408202727 over 14 years ago +3 suggested
    See attached. It's a context file in the meantime. Load it by using the commands: In Skill (or allegro.ilinit): loadContext("EDAVE_clearPinSilk.cxt") axlCmdRegister("clear pin silk" 'EDAVE_clearPinSilk…
  • DE202408202727
    DE202408202727 over 4 years ago in reply to PK1234 +2
    community.cadence.com/.../3343.EDAVE_5F00_clearPinSilk.zip Hopefully the attached revision has sorted the problems
  • oldmouldy
    oldmouldy over 14 years ago +1
    Surely, when designing the symbol, you don't draw the silkscreen over the pins anyway??
  • DE202408202727
    0 DE202408202727 over 14 years ago
    Thanks for finding that bug :-)
    See the attached, hopefully improved, version.
    Cheers,
    Dave
    EDAVE_clearPinSilk.zip
  • soori3
    0 soori3 over 14 years ago
    Hello Dave,
     It works great ... but the only small issue is, still it was not working for silkscreen bottom.
    Thanks &  Regards,
    Suresh Annam
  • DE202408202727
    See attached.
    This version will also prompt you if you pass nil for either of the values.
    Dave
  • soori3
    Hello Dave,
    Its working but i think for silkscreen bottom also it is taking the soldermask top as reference.....
    Thanks & Regards,
    Suresh
  • DE202408202727
    Yes, there was a small bug. See attached.
