  3. Clear silkscreen from pins in Allegro Package
  • State Suggested Answer
  • Replies 110
  • Answers 2
  • Subscribers 177
  • Views 120470
chads108
chads108 over 14 years ago
 Does anyone have some SKILL code that will clear silkscreen lines back x distance from pins, either as a group or individually?  I want to use this during footprint building.  Currently I have to use delete and cut to remove pieces of lines that run through pads.
  • DE202408202727
    DE202408202727 over 14 years ago +3 suggested
    See attached. It's a context file in the meantime. Load it by using the commands: In Skill (or allegro.ilinit): loadContext("EDAVE_clearPinSilk.cxt") axlCmdRegister("clear pin silk" 'EDAVE_clearPinSilk…
  • DE202408202727
    DE202408202727 over 4 years ago in reply to PK1234 +2
    community.cadence.com/.../3343.EDAVE_5F00_clearPinSilk.zip Hopefully the attached revision has sorted the problems
  • oldmouldy
    oldmouldy over 14 years ago +1
    Surely, when designing the symbol, you don't draw the silkscreen over the pins anyway??
  • soori3
    0 soori3 over 14 years ago
    Here i am having some more issues while running the context file
    1). It is not working for silkscreen bottom.
    2). It is not working properly for circular silkscreen.
          a. Creating an extra circle with lesser radius
          b. Not clearing properly at the right side bottom of the circle.
    Suresh Annam
  • chads108
    0 chads108 over 14 years ago
    Yes, just like you would call any other SKILL routine.  Here is a line from my menu:
     MENUITEM "Clear SS 0.15mm...",                    "clear pin silk 0.15 0.2"
    Chad
  • soori3
    Hello Dave
    Can you please help me for clearing the issue that i mentioned above
    Suresh
  • DE202408202727
    0 DE202408202727 over 14 years ago
    Yes, as Chad said, add a line like this somewhere appropriate in your allegro.men menu file:
    You shouldn't edit the installation menu file. Copy a new one from C:\Cadence\SPB_16.5\share\pcb\text\cuimenus\allegro.men to a path that you need to set in your user preferences menupath variable. You can test it first by placing it in your working directory.
  • soori3
    Hello Dave,
    I got it with the menu file but i am facing issue as i mentioned below please help me
    Suresh Annam
