  3. Clear silkscreen from pins in Allegro Package
  • State Suggested Answer
  • Replies 110
  • Answers 2
  • Subscribers 177
  • Views 120461
chads108
chads108 over 14 years ago
 Does anyone have some SKILL code that will clear silkscreen lines back x distance from pins, either as a group or individually?  I want to use this during footprint building.  Currently I have to use delete and cut to remove pieces of lines that run through pads.
  • DE202408202727
    DE202408202727 over 14 years ago +3 suggested
    See attached. It's a context file in the meantime. Load it by using the commands: In Skill (or allegro.ilinit): loadContext("EDAVE_clearPinSilk.cxt") axlCmdRegister("clear pin silk" 'EDAVE_clearPinSilk…
  • DE202408202727
    DE202408202727 over 4 years ago in reply to PK1234 +2
    community.cadence.com/.../3343.EDAVE_5F00_clearPinSilk.zip Hopefully the attached revision has sorted the problems
  • oldmouldy
    oldmouldy over 14 years ago +1
    Surely, when designing the symbol, you don't draw the silkscreen over the pins anyway??
  • DE202408202727
    0 DE202408202727 over 14 years ago
    Add the path to the context file in the loadContext command: eg: loadContext("C:/MySkill/EDAVE_clearPinSilk/EDAVE_clearPinSilk.cxt") This context will only work in 16.5
  • soori3
    0 soori3 over 14 years ago
    hello dave,
    thanks for your reply
    i enterd in command as you mentioned above but i got an error as shown below please help
    error
  • chads108
    0 chads108 over 14 years ago
    Suresh,
    Hopefully this will help.  Here is a copy of my entire allegro.ilinit file.  This SKILLl routine works for me, so I know that this is correct.  My allegro.ilinit file is in the same folder as my SKILL files.  I have this allegro.ilinit file set up to load all the SKILL files I currently have in the directory.  Notice especially the last two lines which load the SKILL routine in question.
    unless(boundp('LoadSkillFilesDebug)
            LoadSkillFilesDebug = axlGetVariable("LoadSkillFilesDebug"))
    when(LoadSkillFilesDebug printf("\n"))
    (foreach file (rexMatchList "\\.il$" (getDirFiles "."))
          when(LoadSkillFilesDebug printf("Loading Skill file: %s\n" file))
          (load strcat("./" file))
    (loadContext "EDAVE_clearPinSilk.cxt")
    (axlCmdRegister "clear pin silk" 'EDAVE_clearPinSilk ?cmdType "interactive")
  • soori3
    Hello Chads,
    Its works great thank u so much for your help ....:)
    And also Dave thanks for your context file...:) it is simply super
    Suresh Annam
  • DE202408202727
    You must load the Skill lines one at a time.
    Many new users must fall into this trap.You might like to raise a service request with Cadence to try to get this changed.
