  3. Clear silkscreen from pins in Allegro Package
  • State Suggested Answer
  • Replies 110
  • Answers 2
  • Subscribers 177
  • Views 120451
chads108
chads108 over 14 years ago
 Does anyone have some SKILL code that will clear silkscreen lines back x distance from pins, either as a group or individually?  I want to use this during footprint building.  Currently I have to use delete and cut to remove pieces of lines that run through pads.
  • DE202408202727
    DE202408202727 over 14 years ago +3 suggested
    See attached. It's a context file in the meantime. Load it by using the commands: In Skill (or allegro.ilinit): loadContext("EDAVE_clearPinSilk.cxt") axlCmdRegister("clear pin silk" 'EDAVE_clearPinSilk…
  • DE202408202727
    DE202408202727 over 4 years ago in reply to PK1234 +2
    community.cadence.com/.../3343.EDAVE_5F00_clearPinSilk.zip Hopefully the attached revision has sorted the problems
  • oldmouldy
    oldmouldy over 14 years ago +1
    Surely, when designing the symbol, you don't draw the silkscreen over the pins anyway??
  • soori3
    0 soori3 over 14 years ago
    Hello Dave,
     At present the CDS_ROOT maps to D:\adw\local_tools\spb_162
    Thanks & Regards,
    Suresh Annam
  • DE202408202727
    0 DE202408202727 over 14 years ago
    CDSROOT should point to your Cadence installation (c:\cadence\spb_16.5)
    ALLEGRO_SITE should point to your site setup folder: eg. X:\CadenceSetup\pcb
    A Skill folder should exist below this. eg.  X:\CadenceSetup\pcb\Skill
    Place your Skill files (including  allegro.ilinit and context files) in there
    axlCmdRegister("clear pin silk" 'EDAVE_clearPinSilk ?cmdType "interactive")
    Type  clear pin silk on the command line to execute the code.
    Dave
  • soonlin
    0 soonlin over 14 years ago
     Hi, Dave, do i need to put in the following statement in the skill command
    It shown W- *WARNING* (reader): extra ')' ignored at line 1 of string ""interactive")"
    "interactive"
    and when i type in the command line with clear pin silk
    error command is
    E- Command not found: clear pin silk
    Please advise.
    Thanks & regards,
  • DE202408202727
    Type these three lines (one at a time) into your Allegro console window:
    skill loadContext("EDAVE_clearPinSilk.cxt")
    skill axlCmdRegister("clear pin silk" 'EDAVE_clearPinSilk ?cmdType "interactive")
    clear pin silk
  • soori3
    Hello Dave,
     i have placed the cxt file in the skill folder
    and if i execute iam getting the below error
    Skill >  loadContext("EDAVE_clearPinSilk.cxt")
    E- *Error* loadContext: could not open file - "EDAVE_clearPinSilk.cxt"
    ERROR
    Skill >
    If i enter the three lines(one at a time) into your Allegro console window
    Skill > skill loadContext("EDAVE_clearPinSilk.cxt")
    clear pin silk 0.24 0.2
    E- *Error* eval: unbound variable - pin
    ERROR
    Suresh Annam
