  3. Clear silkscreen from pins in Allegro Package
  • State Suggested Answer
  • Replies 110
  • Answers 2
  • Subscribers 177
  • Views 120436
chads108
chads108 over 14 years ago
 Does anyone have some SKILL code that will clear silkscreen lines back x distance from pins, either as a group or individually?  I want to use this during footprint building.  Currently I have to use delete and cut to remove pieces of lines that run through pads.
  • DE202408202727
    DE202408202727 over 14 years ago +3 suggested
    See attached. It's a context file in the meantime. Load it by using the commands: In Skill (or allegro.ilinit): loadContext("EDAVE_clearPinSilk.cxt") axlCmdRegister("clear pin silk" 'EDAVE_clearPinSilk…
  • DE202408202727
    DE202408202727 over 4 years ago in reply to PK1234 +2
    community.cadence.com/.../3343.EDAVE_5F00_clearPinSilk.zip Hopefully the attached revision has sorted the problems
  • oldmouldy
    oldmouldy over 14 years ago +1
    Surely, when designing the symbol, you don't draw the silkscreen over the pins anyway??
  • DE202408202727
    0 DE202408202727 over 14 years ago
    It is Skill - just not editable. Load it per the instructions above.
  • soonlin
    0 soonlin over 14 years ago
    Hi, Dave,
    i got it, thanks.
    Soon Lin, Lim - PCB Designer
  • soori3
    0 soori3 over 14 years ago
    Hello dave,
    I am new to use these skill files can you please help me how to use this silkscreen clearance skill file.
    Thanks & Regards,
    Suresh Annam
  • DE202408202727
    Hi Suresh,
    The instructions are in the header of the file. Open it in a text editor and give it a try.
    Let me know if you have any problems.
    Dave
  • soori3
    Hello Dave,
     Thanks for your reply,
     Before i start with the skill files loading what i need to map the CDS_ROOT and HOME paths...?
    At present i have created a folder skill at the location  D:\adw_projects\pcbenv\
    And also i have created a text file and changed the extension to .ilinit and placed the file in the above location
     Thanks & Regards,
    Suresh Annam
