  3. Clear silkscreen from pins in Allegro Package
  • State Suggested Answer
  • Replies 110
  • Answers 2
  • Subscribers 177
  • Views 120566
chads108
chads108 over 14 years ago
 Does anyone have some SKILL code that will clear silkscreen lines back x distance from pins, either as a group or individually?  I want to use this during footprint building.  Currently I have to use delete and cut to remove pieces of lines that run through pads.
  • DE202408202727
    DE202408202727 over 14 years ago +3 suggested
    See attached. It's a context file in the meantime. Load it by using the commands: In Skill (or allegro.ilinit): loadContext("EDAVE_clearPinSilk.cxt") axlCmdRegister("clear pin silk" 'EDAVE_clearPinSilk…
  • DE202408202727
    DE202408202727 over 4 years ago in reply to PK1234 +2
    community.cadence.com/.../3343.EDAVE_5F00_clearPinSilk.zip Hopefully the attached revision has sorted the problems
  • oldmouldy
    oldmouldy over 14 years ago +1
    Surely, when designing the symbol, you don't draw the silkscreen over the pins anyway??
  • DE202408202727
    0 DE202408202727 over 4 years ago in reply to JITHINDEV
    Please send me a dra on which this occurs.
    Cheers,
    Dave
  • JITHINDEV
    0 JITHINDEV over 4 years ago in reply to DE202408202727
    Hi Dave,
    Please find the attachment
    Jithindevhttps://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/APXG250ARA221MJA0G.zip
  • DE202408202727
    Please see attached.
    Sorry for the delay. The problem was caused by a bug in a Skill command (now reported)https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/4520.EDAVE_5F00_clearPinSilk.zip
  • JITHINDEV
    Thanks Dave. It works great.
    Jithindev
  • Jarez95
    0 Jarez95 over 3 years ago
    This can be done automatically in Allegro using the 'Silkscreen' option in manufacturing: Cadence PCB Interactive Automatic Silkscreen - YouTube
    Not sure if it was there in the older versions, but definitely there in 17.2
