  3. Clear silkscreen from pins in Allegro Package
  • State Suggested Answer
  • Replies 110
  • Answers 2
  • Subscribers 177
  • Views 120565
chads108
chads108 over 14 years ago
 Does anyone have some SKILL code that will clear silkscreen lines back x distance from pins, either as a group or individually?  I want to use this during footprint building.  Currently I have to use delete and cut to remove pieces of lines that run through pads.
  • DE202408202727
    DE202408202727 over 14 years ago +3 suggested
    See attached. It's a context file in the meantime. Load it by using the commands: In Skill (or allegro.ilinit): loadContext("EDAVE_clearPinSilk.cxt") axlCmdRegister("clear pin silk" 'EDAVE_clearPinSilk…
  • DE202408202727
    DE202408202727 over 4 years ago in reply to PK1234 +2
    community.cadence.com/.../3343.EDAVE_5F00_clearPinSilk.zip Hopefully the attached revision has sorted the problems
  • oldmouldy
    oldmouldy over 14 years ago +1
    Surely, when designing the symbol, you don't draw the silkscreen over the pins anyway??
  • DE202408202727
    0 DE202408202727 over 4 years ago in reply to PK1234
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/3343.EDAVE_5F00_clearPinSilk.zip
    • Vote Up +2 Vote Down
  • PK1234
    0 PK1234 over 4 years ago in reply to DE202408202727
    Thanks Dave. It works great on both .brd and .pad files Grinning It works in 17.4 as well.
  • JITHINDEV
    0 JITHINDEV over 4 years ago in reply to DE202408202727
    Hi eDave,
    How to load the skill in allegro.ilinit.
    Jithindev
  • DE202408202727
    0 DE202408202727 over 4 years ago in reply to JITHINDEV
    Add these lines to your allegro.ilinit file (obviously replace <path to skill> with your Skill path):
    loadContext("<path to skill>/64bit/EDAVE_clearPinSilk.cxt")
    axlCmdRegister("clear pin silk" 'EDAVE_clearPinSilk ?cmdType "interactive")
  • JITHINDEV
    Thanks Dave, It is working. But there is an issue I am facing, when the skill we used for circle, sometimes circle get enlarged and overlapping with pad in both .dra and .brd
