  3. Clear silkscreen from pins in Allegro Package
  • State Suggested Answer
  • Replies 110
  • Answers 2
  • Subscribers 177
  • Views 120559
chads108
chads108 over 14 years ago
 Does anyone have some SKILL code that will clear silkscreen lines back x distance from pins, either as a group or individually?  I want to use this during footprint building.  Currently I have to use delete and cut to remove pieces of lines that run through pads.
  • DE202408202727
    DE202408202727 over 14 years ago +3 suggested
    See attached. It's a context file in the meantime. Load it by using the commands: In Skill (or allegro.ilinit): loadContext("EDAVE_clearPinSilk.cxt") axlCmdRegister("clear pin silk" 'EDAVE_clearPinSilk…
  • DE202408202727
    DE202408202727 over 4 years ago in reply to PK1234 +2
    community.cadence.com/.../3343.EDAVE_5F00_clearPinSilk.zip Hopefully the attached revision has sorted the problems
  • oldmouldy
    oldmouldy over 14 years ago +1
    Surely, when designing the symbol, you don't draw the silkscreen over the pins anyway??
  • PK1234
    0 PK1234 over 4 years ago
    Hello Dave, We have shape on top silkscreen to define pin#1. When we run the the script, it converts shape to line. Any solution for that? Attached example file.
  • DE202408202727
    0 DE202408202727 over 4 years ago in reply to PK1234
    Which version are you running?
  • PK1234
    0 PK1234 over 4 years ago in reply to DE202408202727
    Tried on both Allegro 17.2 and 17.4. Having same issue. I have attached cxt file that I am using. This version works great with arc and circle as well.  Attached Image of issue as well. https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/2604.EDAVE_5F00_clearPinSilk-_2800_4_2900_.zip
  • DE202408202727
    Try this version. (17.2)
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/6607.EDAVE_5F00_clearPinSilk.zip
  • PK1234
    Same issue. Tried with 17.2 S081. All shapes are converted to line whether it's over copper or not.
