  3. Nearest Neighbor Problem
  • Replies 9
  • Subscribers 166
  • Views 18997
vramananx
vramananx over 14 years ago
Hi
I am trying to implement the nearest neighbor problem in skill, can anyone help me with some examples and tutorials?
basically i am tryint to get the closest point in a list of points for a given x,y
I am using sortcar to do this but it is very slow since there is a huge amount of calculation goes on
So I would like to use any NNP algorithm and would like some pointers,
 regards
Venkata
  • Ejlersen
    Ejlersen over 14 years ago
    Hi
    If you just need the closest point, what's wrong with just running through each element and calculating the distance
    closestpoint = car(listofpoints)
    shortestdistance = axlDistance(referencepoint closestpoint)
    foreach(pid listofpoints
    when(axlDistance(referencepoint lid) < shortestdistance
    shortestdistance = axlDistance(referencepoint lid)
    closestpoint = lid
    that should return the closest point and the shortest distance.
    Best regards
    Ole
  • vramananx
    Hi Ole
    Long time
    there is nothing wrong with your suggestion, that's what i do currently
    for each point
    i append the axldistance from that point to the nearest point's db (list=cons(axldistance(pt1 pt2) list) list=cons(pt2db list))
    then I append that list to another list, then i use sortcar to find the shortest distance and its db
    But the number of points is based upon the number of layer sets, for a 6 layer board it is 3 sets, 8 layer is 4 sets and so on
    now lets say i got 1000+points in each layer set and have to check each and everyone of them to another set of 1000 so it is a factor of
    4.02387260077093773543702433923e+2567 calculations times then number of layer sets
    This becomes an huge issue for a big database
    I was looking at implementing KD-Tree, i will let you know how it goes
    regards
    venkata
  • vramananx
    Hi Ole
    I used 1000! infact it should be 1000 times 1000
    regards
  • vramananx
    in anycase I am trying to implement kd-tree
    I have a way to sort the list of points,
    divide them by their median,
    then sort them by y value
    now i have to figure out a way to add them to a parent->child relation
    I am considering using arrays and tables
    if you have any ideas please let me know
    basically i want this structure
    Parent
        -right child----left and right child
          -left child----left and right child
    please refer http://en.wikipedia.org/wiki/K-d_tree regards vramanan
  • Ejlersen
    Hi Venkata
    I'm sorry but I have no experience in kd tree's and never done anything to handle so much data that computing speed would be an issue, so I have no real experience in recommending arrays versus lists.
    Best regards
    Ole
