  3. How to edit the footprint in PCB board
  • Replies 15
  • Subscribers 166
  • Views 32007
AamirZ
AamirZ over 14 years ago
Hi every one
I have routed PCB board  .brd file (no schematic). I want to edit some components footprint like capacitor and diode place on the board have no polarity. Any body have knowledge about the procedure to edit the already placed and routed footprints.
 Regards
Aamir
  • DawnC
    DawnC over 13 years ago
    If it were me...
    1)  Save a copy of the brd
    2) File export placement
    3)  edit the placement.txt file created.  Find U29 and update the footprint to what you want.
    4) import the updated placement.txt back into the brd file.
    hope that helps.
  • Bonz
    Bonz over 13 years ago
    I'm unsure why it should be any different than placing the D2PAK. Nonetheless...
    Dawn proposes a simple solution (though I can't vouch for its success because I've never done it).
    If it were me, I'd delete U29, place a TO263 then go to the toolbar within PCB Designer to "Logic > Assign RefDes", specify U29 in the options panel and left click on the new TO263 package.
  • AamirZ
    AamirZ over 13 years ago
    Thanks Bonz, when i do your define process following error is shown
    For refdes 'U29' symbol 'TO263-3' is not legal for placement layer. Check ALT_SYMBOL and ALT_SYMBOL_HARD property settings.
  • Bonz
    Yeah, forgive me... I've just tried it myself. I think I've just given you some duff information to be honest. I don't get the same problem as you. I can place, but just can't change the RefDes. It appears I need the RefDes in the netlist in order to assign one. Hope you're a little bit closer though :)
  • AamirZ
    OK Bonz no problem i think you peoples understand my problem
