  3. How to edit the footprint in PCB board
  • Replies 15
  • Subscribers 166
  • Views 32013
AamirZ
AamirZ over 14 years ago
Hi every one
I have routed PCB board  .brd file (no schematic). I want to edit some components footprint like capacitor and diode place on the board have no polarity. Any body have knowledge about the procedure to edit the already placed and routed footprints.
 Regards
Aamir
  • AamirZ
    AamirZ over 13 years ago
    Dawn I do your process. I export placement file, delete U29, change D2PAK with TO-263-3 in placement file, import placement file nothing happen but when I change D2PAK again, import file again it place D2PAK with REFDES U29. I Think I do some wrong kindly correct me.
  • DawnC
    DawnC over 13 years ago
    Do you have the TO-263-3 footprint defined?  A quick test, do a Place Manual (Advanced tab make sure "librry" is selected).  Placement List pull down to Package Symbols.  Do you see the TO-263-3?
  • AamirZ
    Yes DAWN TO263-3 is see in placement list and place on the board
  • AamirZ
    It is shown as attached picture. 1.PNG is the figure of U29 which i want to replace with TO263-3
  • Luc S
    Luc S over 13 years ago
    Just export your library in the path where is you brd file by using the File-->Export--Libraries, check all the options, let the dot in the directory line and click OK. You obtain all your packages and pads file...
    Export the netlist by using the File-->Export-->Netlist/w properties, edit the netlist.txt file then replace your package component in it. The file structure is easy to understand. Use the file import-->Logic, folder other and check supersede all logical datas, the clic on import...
    You will see the changes immediately.
    Regards
