  3. Can you use axlRunBatchDBprogram("notepad" ......) to open...
  • Subscribers 163
  • Views 3169
Can you use axlRunBatchDBprogram("notepad" ......) to open an attached file?
jwhend
jwhend over 13 years ago
 Hi all,
I created an attached file, using axlCreateAttach(), I want to open the attachment in notepad. Is there a way to use axlRunBatchDBprogram() to open it and edit the file? If so, what would be the syntax?
Jerry
  • jwhend
    I got this, almost, working using :
     axlRunBatchDBProgram("mynotepad" sprintf(nil, "notepad %s",axlGetAttachment("attach3" 'file)->data ?noUnload t ?noProgress t)
    The only issue is that the text is missing returns. It comes in all one line. Any suggestions??
    Jerry
  • DE202408202727
    DE202408202727 over 13 years ago
    Have you tried using wordpad instead of notepad?
  • jwhend
     Hi Dave,
    I tried using wordpad, but for some reason skill does not find the program. I tried to run wordpad at the cmd window and was not able to do that either.
    I contacted our IT guy and I'm waiting to see what he says.
    Could the issue be using %s? Is sprintf converting the file into a single string?
    Jerry
  • DE202408202727
    Oddly enough, you have to call write.exe to load wordpad
  • jwhend
     Thanks Dave!! That works perfectly.
    Thanks, Again
    Jerry
