  3. Need guidance on how to select nets, pads, and vias with...
  • Replies 19
  • Views 26738
Need guidance on how to select nets, pads, and vias with a certain property
mesaman000
mesaman000 over 13 years ago
  I'm a beginner to SKILL programming and I took the basic tutorial class but seems to not be many resources for what I need to do.  I'm trying to initialize all pads, etch, via, nets, and shapes to a certain color like GREY.  Once I do that, I want to search the PCB editor database and identify which nets have a certain spacing class property: "1" "2" "3" or "4".   I want all pads and vias with the spacing class property 1 to be RED for example, all pads and vias with the spacing class property 2 to be BLUE, etc.
 Lastly, I want to export a PDF of this color map.  Can someone please help give me an idea of how I can achieve something like this?
Something I've started with is roughly like this:
design_dbid=axlDBGetDesign()
scset=axlCnsList("spacing") ;**Say my four spacing constraints are Default, 1, 2, 3, 4
**how do I traverse through all pads and vias?**
comp_dbid_list=design_dbid->components (pads isn't a property of design_dbid, is this the right method?)
foreach(comp_dbid comp_dbid_list
if comp_dbid->scset==1
**how do I change the color of these to RED?
If anyone could provide any guidance or help it would be great!  Thank you!
  • DE202408202727
    DE202408202727 over 13 years ago
    It's tough to start your Skill life with something like this.
    Here is some code to get you started:
    red = listnindex(axlColorGet('all), '(255 0 0)) || 7
    gray = listnindex(axlColorGet('all), '(190 190 190)) || 2
    spacingConstraint = "TEST"
    foreach(layer, '("ETCH/TOP" "PIN/TOP", "VIA CLASS/TOP"), q = axlLayerGet(layer), q ->color = gray, axlLayerSet(q))
    axlClearObjectCustomColor(axlDBGetDesign() ->nets)
    axlSetFindFilter( ?enabled '("noall" "pins") ?onButtons "pins")
    axlAddSelectAll()
    pins = axlGetSelSet()
    axlClearObjectCustomColor(pins)
    csetNets = axlSelectByProperty("net", "SPACING_CONSTRAINT_SET", spacingConstraint)
    red_pins = setof(pin, pins, member(pin ->net, csetNets))
    axlCustomColorObject(red_pins, red)
    axlVisibleUpdate(t)
    Plottting to a pdf  might be more difficult.
  • mesaman000
    Hey Dave,
      Thanks a ton for the help.
    Just so I can understand a little better, I have a couple questions for you if you don't mind:
    1) Do you know where I can find what arguments these functions take?  I can be a little more independent if I had access to any of these syntaxes but the basic SKILL programming class doesn't really go over any of this stuff besides basic syntax like strcat, local variables, etc.  I've tried searching google all over and can't find what arguments belong to what functions.  I've also tried in the skill prompt to type "help(listnindex)" for example and can't find any documentation
    2) When I try getting the first part to work (just setting everything to gray), nothing happens.  I actually only care about the bottom and top layers being initialized to gray, but anyway I figured it would look something like:
      axlVisibleUpdate(t)
    3) lastly,  I want to set all pins AND vias to the color if they are associated with that specific spacing constraint.  I've modified it to be this:
      axlSetFindFilter( ?enabled (list "noall" "pins" "vias" "invisible")  ?onButtons (list "pins" "vias"))
    axlAddSelectAll()
    pins_and_vias = axlGetSelSet()
    axlClearObjectCustomColor(pins_and_vias)
    red_pins_and_vias = setof(pin, pins_and_vias, member(pin ->net, csetNets))
    Thanks again for your help!
  • DE202408202727
    1/ The user and reference manuals are a good place to start. ...\doc\sklangref\sklangref.pdf and ...\doc\sklanguser\sklanguser.pdf. Another quick reference is to look in the documentation for each function ...\share\pcb\examples\skill\DOC\FUNCS
    2/ That should work. Do you get any error messages? Maybe you have some hilighting. Try removing that.
    3/ OK. But don't forget to set the spacingConstraint variable to something.
  • mesaman000
    Hi Dave,
      I'm still having trouble setting everything to a grey color initially..  I tried
    gray = 81 ;; this is the index from the listnindex(axlColorGet('all) for the gray color I want
    ;;axlClearObjectCustomColor(axlDBGetDesign() ->nets)
    axlVisibleUpdate(t)
    Why won't this work?
    I'm able to set my pins red using the axlCustomColorObject(list,red), but for some reason I can't color everything else initially to grey.
    Really appreciate the help.  Thanks!
  • DE202408202727
    Why have you commented out the clearing of the custom colours?
