  3. Need guidance on how to select nets, pads, and vias with...
  • Replies 19
  • Views 26739
Need guidance on how to select nets, pads, and vias with a certain property
mesaman000
mesaman000 over 13 years ago
  I'm a beginner to SKILL programming and I took the basic tutorial class but seems to not be many resources for what I need to do.  I'm trying to initialize all pads, etch, via, nets, and shapes to a certain color like GREY.  Once I do that, I want to search the PCB editor database and identify which nets have a certain spacing class property: "1" "2" "3" or "4".   I want all pads and vias with the spacing class property 1 to be RED for example, all pads and vias with the spacing class property 2 to be BLUE, etc.
 Lastly, I want to export a PDF of this color map.  Can someone please help give me an idea of how I can achieve something like this?
Something I've started with is roughly like this:
design_dbid=axlDBGetDesign()
scset=axlCnsList("spacing") ;**Say my four spacing constraints are Default, 1, 2, 3, 4
**how do I traverse through all pads and vias?**
comp_dbid_list=design_dbid->components (pads isn't a property of design_dbid, is this the right method?)
foreach(comp_dbid comp_dbid_list
if comp_dbid->scset==1
**how do I change the color of these to RED?
If anyone could provide any guidance or help it would be great!  Thank you!
  • mesaman000
    Oops, forgot to delete the ;; from the post.  This is actually what I'm testing:
    ;;gray = listnindex(axlColorGet('all), '(0 255 255))
    gray = 81
    foreach(layer, '("ETCH/TOP" "PIN/TOP", "VIA CLASS/TOP"), q = axlLayerGet(layer), q ->color = gray, axlLayerSet(q))
    axlClearObjectCustomColor(axlDBGetDesign() ->nets)
    axlVisibleUpdate(t)
  • DE202408202727
    DE202408202727 over 13 years ago
    Ok, it works for me. Have you turned all other layers (such as PIN/SOLDERMASK_TOP) off?
  • mesaman000
    Everything works beautifully now!  Thanks a ton for your help Dave.
    The last part I need to complete on this script is doing this for both pins and vias.  The code works the way I want it for just pins now, but how would I also add vias?
    axlSetFindFilter( ?enabled (list "noall" "pins" "vias" "invisible")  ?onButtons (list "pins" "vias"))
    axlAddSelectAll()
    pins_and_vias = axlGetSelSet()
    axlClearObjectCustomColor(pins_and_vias)
    csetNets1 = axlSelectByProperty("net", "SPACING_CONSTRAINT_SET", spacingConstraint1)
    red_pins = setof(pin, pins_and_vias, member(pin ->net, csetNets1))
    csetNets2 = axlSelectByProperty("net", "SPACING_CONSTRAINT_SET", spacingConstraint2)
    green_pins = setof(pin, pins_and_vias, member(pin ->net, csetNets2))
    csetNets3 = axlSelectByProperty("net", "SPACING_CONSTRAINT_SET", spacingConstraint3)
    yellow_pins = setof(pin, pins_and_vias, member(pin ->net, csetNets3))
    axlCustomColorObject(red_pins, red)
    axlCustomColorObject(green_pins, green)
    axlCustomColorObject(yellow_pins, yellow)
    axlVisibleUpdate(t)
    When I do the 'setof' command, how would I also add dbids for vias into that set?  Right now it only collects pins with that spacing class property.  I tried doing them separately like
    yellow_via= setof(via, pins_and_vias, member(via ->net, csetNets3))
    axlCustomColorObject(yellow_via, yellow)
    but that did not work the way I wanted.  Any suggestions would really be appreciated.  Thanks a ton for all of your help!
  • DE202408202727
    What you had done should have worked. Try typing
    unique(pin_and_vias ~>objType)
    It should return ("pin" "via")
  • mesaman000
    Yes, here's what I do in my code:
    dd=unique(pins_and_vias ~>objType)
    println(dd)
     and it returns ("pin" "via")
    so I validate that pins_and_vias is the set of all pins and vias on the board, so I'm confused why only the pins get the colors update and the vias dont..  This is word for word the code I'm using:
    red = 1
    green = 24
    yellow = 4
    gray = 81
    spacingConstraint1 = "TEST1"
    spacingConstraint2 = "TEST2"
    spacingConstraint3 = "TEST3"
    axlAddSelectAll()
    println(dd)
    red_via = setof(via, pins_and_vias, member(via ->net, csetNets1))
    green_via = setof(via, pins_and_vias, member(via ->net, csetNets2))
    axlCustomColorObject(red_via, red)
    axlCustomColorObject(green_via, green)
    axlVisibleUpdate(t)
