  3. Need guidance on how to select nets, pads, and vias with...
  • Replies 19
  • Views 26745
Need guidance on how to select nets, pads, and vias with a certain property
mesaman000
mesaman000 over 13 years ago
  I'm a beginner to SKILL programming and I took the basic tutorial class but seems to not be many resources for what I need to do.  I'm trying to initialize all pads, etch, via, nets, and shapes to a certain color like GREY.  Once I do that, I want to search the PCB editor database and identify which nets have a certain spacing class property: "1" "2" "3" or "4".   I want all pads and vias with the spacing class property 1 to be RED for example, all pads and vias with the spacing class property 2 to be BLUE, etc.
 Lastly, I want to export a PDF of this color map.  Can someone please help give me an idea of how I can achieve something like this?
Something I've started with is roughly like this:
design_dbid=axlDBGetDesign()
scset=axlCnsList("spacing") ;**Say my four spacing constraints are Default, 1, 2, 3, 4
**how do I traverse through all pads and vias?**
comp_dbid_list=design_dbid->components (pads isn't a property of design_dbid, is this the right method?)
foreach(comp_dbid comp_dbid_list
if comp_dbid->scset==1
**how do I change the color of these to RED?
If anyone could provide any guidance or help it would be great!  Thank you!
  • DE202408202727
    DE202408202727 over 13 years ago
    You are only setting the TOP layer to gray.
    Try:
    foreach(subclass, axlSubclasses("ETCH")
    foreach(class, '("ETCH" "PIN", "VIA CLASS"), q = axlLayerGet(strcat(class, "/", subclass)), q ->color = gray, axlLayerSet(q))
  • mesaman000
    hm.. but how does that help the via coloring problem I'm having?
  • DE202408202727
    I still think that your code should work. You may just need to refresh your view and ensure that you are just looking at etch layers.
  • mesaman000
    Hey Dave,
      I've attached a picture of what's happening even after setting all layers/subclasses to become grey and turning universal colors on (all laeyrs are shown but this is only a 2 layer board with a ground plane on the bottom).  All the pads are correct but my vias still will not set for whatever reason..
    Script problem
    Thanks again
  • Aldrin
    Aldrin over 13 years ago
    This is because axlCustomColorObject command doesn't support vias for allegro version 16.5 and below as the documentation stated as follows.
    Custom color the provided dbid or list of dbids. Objects supported are nets, symbol instances,pins, and external DRCs.
