  3. skill code for placing components around circle (polar placement...
  • Replies 18
  • Subscribers 166
  • Views 30950
skill code for placing components around circle (polar placement)
KARPCB
KARPCB over 12 years ago
 Hi ,
Anyone have  skill code for placing components around circle (polar placement) ?
Karthik
  • KARPCB
    KARPCB over 11 years ago
    Thank you very much for your effort and sharing the code.
  • DE202408202727
    DE202408202727 over 11 years ago
    Hi Arumugam Petchi,
    The code has got nice functionality for those designers needing polar placement. Good job
    A few minor observations:
    1. All your variables are global. This is bad practice in any language. Use the let statement and try to include all variables. If variables must be global, use a complex name that cannot conflict with other Skill and declare them using defvar.
    2. I prefer to use embedded forms now they are available. It makes your Skill more robust. Check the documentation for axlFormCreate.
    3. I think this form should not use the string option. Indeed I never user this as I think it's unnecessary with good coding.
    4. Select symbol, Symbol angle and Direction fields could be outside the tabs as they are common to both. Indeed it doesn't really seem necessary to have two tabs. A "Circle" check box might be easier. Grey out the Start/End angle box when circle selected.
    5. Direction (misspelled) could be a drop-down selection list
    6. I suggest you add default values in your form for radius, angles and direction. Maybe you can store the values to pre-populate the form next time it is run (maybe the only excuse for using global variables or a design property).
    Dave
  • AARUPCB
    AARUPCB over 11 years ago
    Dear Dave,
    Thanks for your valuable feedback.
    Thanks for pointing out the things that make my code robust. I will try to ignore those unnecessary things.
    Few Doubts Dave, Pls clarify.
    1. May i know the name of this skill language.
    2. As of now i am using wordpad for coding, Is there any Software Tools for this coding.
    Thanks & Regards,
    Arumugam Petchi.
  • Ejlersen
    Ejlersen over 11 years ago
    Hi
    There are several editors that are more suitable than wordpad/notepad
    I mostly use notepad++ which is free and where you can enhance it with SKILL syntax
    If you look at the link below it should point you to a google translated version of  http://www.nordcad.dk/dk/teknik__service/e-service/e-service_nr_139.htm
    Best regards
    Ole
  • DE202408202727
    I recommend Notepad++ but I use UltraEdit.
