  3. Call Python program from Skill?
  • Subscribers 166
  • Views 22533
thewill2live
thewill2live over 12 years ago
Hi all,
Is there a way to call a python program from Skill? Perhaps through accessing the Windows CMD line? I have a python program I wrote to edit the alias list in the allegro env file that I want to call from my Skill program (seeing as how I cannot apply aliases permanently through SKILL, only temporarily). Is there a command that will allow me to call the python program from inside my Skill program?
  • rflayout
    rflayout over 11 years ago
    Take a look at this thread
    http://community.cadence.com/cadence_technology_forums/f/48/t/20072
  • Bleslie
    Bleslie over 8 years ago
    You can use the shell() skill command to run another program from skill.  I believe this will lock Allegro until the command finishes.  If using this in a windows environment you can put the word "start" in front of the command string so it will start the program without locking up Allegro.
    cmdstr = sprintf( nil "start pad_designer.exe %s " padstkfile)
    shell( cmdstr )
    On another note, it sounds like you want to change alias command definitions while in Allegro.   Here is a way to change alias definitions depending on what edit mode your are in.
    https://community.cadence.com/cadence_technology_forums/f/pcb-skill/25933/redefine-function-keys-when-switching-edit-modes
