  3. Extracting Data Similar to Cross Section
  • Views 16179
MGorecki
MGorecki over 12 years ago
Hello, I'm new to SKILL and am trying to write a program that will extract information found in the Layout Cross Section tool.  I need to extract to a text file in a particular format, so I can't use the "Report" button in the Cross Section tool.
I know how to output the text to the file, what I need to know is how to get the data like Conductor layer name, Material, Thickness, Conductivity, Dielectric Constant, and Loss Tangent .
Can someone either show me how to get this data, or where I can go to find info on how to do this?
Mark
  • MGorecki
    Also, I'm using Allegro Package Designer 16.6.
  • fxffxf
    fxffxf over 12 years ago
    You can use extract to dump the cross section
    The simplest which outputs a default cross-section view to foo.txt file. You can post process this file to achieve the file format you need
          axlExtractToFile("layer_bv" "foo.txt)
    You can use axlExtractMap to do the extraction and post-process in one pass
     Finally it you want one skill list of the entire cross section do
        xsection = axlGetXSection
  • MGorecki
    Thank you very much!
