  3. obtaining the list and properties of components in a brd...
  • Replies 7
  • Views 20836
obtaining the list and properties of components in a brd file
Wale
Wale over 11 years ago
Any one out there has an existing SKILL script that list components properties by its Ref Des, Pkg Symbol, Device type, xy coordinates, and also call out properties attached to component instance..
WALE
  • Ejlersen
    Ejlersen over 11 years ago
    Hi
    Thats a rather comprehensive questions,
    To get you kickstarted you could look at the following pseudocode
    Create file with
    myfile = axlDMOpenFile("ALLEGRO_TEXT" "myfilename" "w")
    To obtain all components you could use
    complist = axlDBGetDesign()->components
    Then run through each component using
    foreach(compid complist
    refdes = compid->name
    compx=nth(0 compid->symbol->xy)
    compy=nth(1 compid->symbol->xy)
    fprintf(myfile "%s\t%f\t%f\n" refdes compx compy)
    then run through all properties, if there are any you get them through compid->prop
    and remeber to use axlDMClose when finished writing to the file
    Best regards
    Ole
  • Wale
    Thanks Ole.... Its a good start for me .. it really helped ..
  • Wale
    Hi Ole, Now I want to retrieve the part number from the compponent property... do you know what function to use to call this property from the components list i generated? Thanks .. Wale
  • Ejlersen
    Hi Wale
    When you have the list you can simply use
    compid->compdef->prop->PART_NUMBER
    Best regards
    Ole
  • Wale
    Thanks Ole... it was helpful.... Another thing please.... i am trying to attach the part number (comp_ipn) of this component to a user defined attribute "ASI_MODEL" using axlDBAddProp () function... i get a "not a floating point number error.... is there a way around this? The goal is to attach the partnumber t o ASI_MODEL ............................................................................................................................................................................. foreach(item comp_dbid
    comp_refdes = item->name
    comp_symbol = item->symbol->name
    comp_xy = item->symbol->xy
    comp_ipn = item->compdef->prop->PART_NUMBER
    comp_prop = axlDBGetProperties(item '("user" "allegro"))
    if(car(comp_prop) != "ASI_MODEL"
    comp_prop = axlDBAddProp(item '("ASI_Model", comp_ipn))
