  3. via in pad snaps to pad center.
  • Subscribers 167
  • Views 20032
Lennie
Lennie over 11 years ago
I am trying to copy a gnd via and place it in a QFN center pin . When I place the via  anywhere in the center pad it snaps to the exact center of the pad.  How do I stop this so I can add a number vias ?
  • redwire
    redwire over 11 years ago
    This has been a very frustrating "feature" of 16.x series versions.  It did not use to do that in 15.x series.  I hope some expert can answer this.
    What do I do for now?  Go ahead and let it snap to pad center X number of times and then do a Move->Via and replace the vias where I want them on the pad.
  • DE202408202727
    DE202408202727 over 11 years ago
    Can you not right-click, snap to grid point?
  • mcatramb91
    mcatramb91 over 11 years ago
    I see what you mean, as you start getting closer to pad center the stitch via starts snapping to the pad center.  The snapping doesn't seem to occur along the pad edges of larger pads but as you move closer to the pad center the snapping starts.
    Setting the Environmental Variable  "copy_no_autosnap"  should stop the snapping.    At least it worked for me :-)   Give it a try.
    Hope this helps,
    Mike Catrambone
  • nktty
    nktty over 5 years ago in reply to mcatramb91
    hi, how do i set this? do i just paste it at the env file?
  • steve
    steve over 5 years ago in reply to nktty
    Go to Setup - User Preferences - Interactive and enable the copy_no_autosnap there.
