  3. Snap to intersection while "axlEnterPoint"
  • Views 3067
Hogsmeade
Hogsmeade over 10 years ago
The goal is to place symbols in a polar grid. So I created a skill that draws lines intersecting with circles. Then I pick it and snap to the intersection.
Due to varying angle each placement, I have to use axlTransformObject and axlEnterPoint but axleEnterPoint only support snap to grids (?gridSnap t).
Of course, we can use pop up and select "Snap to intersection" but I want to just pick near the intersection and it automatically snaps to it.
Any suggestion?
I really appreciate it.
  • Hogsmeade
    Btw, is there anyway that could increase the effective range of "Snap pick to intersection"?
  • B Bruekers
    B Bruekers over 10 years ago
    In this case I would use the axlEnterEvent function.
    You get the XY and grid snapped XY points of the user pick. Then write a function that selects everything in a box (axlSingleSelectBox) around this xy point. The bbox size you have to calculate, so can make it as large as you want. If you want to use a box depending on the zoom level use the axlGetTrapBox function. It returns a bbox depending on the zoom level.
    The selection you can do this only specific elements like LINESEGS and use the setof function to filter a specific layer (if required).
    Then find the intersection of the linesegs with the axl_ol_ol2 function. The result is a xy point where to place your component.
  • Hogsmeade
    Thank you Bruekers. It's a good idea.
    I just think of a bit simpler solution to get the intersection point ...
     axlEnterPoint(?prompts "Pick new place ...", ?gridSnap nil)          ;    wait for a pick
    axlShell( "prepopup;pop dyn_option_select 'Snap pick to@:@Intersection'"); this will pick  the intersection of 2 lines
    point = axlLastPick(nil)    ; finally get the last pick coordinate
