  3. Accessing Properties in skill in the symbol editor
  • Views 15857
Lennie
Lennie over 10 years ago
I would like to be able to change a user property with a SKILL program in a loaded symbol (.dra file) . Does anyone have any suggestions on how to do that ?
Tks!
  • DE202408202727
    DE202408202727 over 10 years ago
    Not sure exactly what you mean but try using axlDBAddProp.
  • Lennie
    I have a symbol loaded in the symbol editor.
    I have a property added to the user library using
    axlDBCreatePropDictEntry("Date_Created_Modified" "STRING" "SYMBOL")
    I modified the Date_Created_Modified  by using edit properties and it contains a value.
    when I try to use
    p = axlSelectByProperty("symbol" "DATE_CREATED_MODIFED")
    It always comes back NIL.
    How can I change the property  with axlDBAddProp without being able to set 'p' ?
  • B Bruekers
    B Bruekers over 10 years ago
    To set the property: axlDBAddProp(nil list('DATE_CREATED_MODIFIED "test1"))
    The property is stored here: axlDBGetDesign()->prop
    So, axlDBGetDesign()->prop->DATE_CREATED_MODIFIED  gives you the value.
  • Lennie
    Thanks for the response .I am able to get the correct property value but the cannot set the properly with the line that was provided.
    TIA, Lenny
