  3. AutosilkUtils in 17.2
  • Replies 19
  • Subscribers 167
  • Views 26140
EvanShultz
EvanShultz over 10 years ago
I suspect eDave may be the best person to answer, but any feedback is welcome. After upgrading to 17.2 from 16.6, invoking Allegro shows the following error in the console:
E- *Error* loadContext: could not open file - "64bit/AutosilkUtils_public.cxt"
Is there an updated utility for 17.2? Perhaps I'm doing something wrong?
  • Chise
    Chise over 8 years ago in reply to EvanShultz +1
    hi,the question " E- *Error* loadContext: could not open file - "64bit/AutosilkUtils_public.cxt ",could you been solved?
  • DE202408202727
    DE202408202727 over 8 years ago in reply to Chise +1
    Is your question about AUtoSilkUtils or about creating context files in general?
  • EvanShultz
    EvanShultz over 9 years ago
    Well, that was a big piece of it. I created $CDS_STE/pcb/skill/64bit and once that was done I have no errors when invoking either Allegro version. Thanks!
    But... still broken in Allegro 16.6 on my PC. I still get the following error:
    E- File save problem: Not enough storage is available to process this command.
    E- *Error* axlGRPDrwInit: argument #1 should be any user-defined (other) type (type template = "otg") - nil
    I checked a few other coworkers' PCs (all 16.6) and they're OK. But not for me in 16.6, though 17.2 works OK for me. Weird. Other ideas?
  • DE202408202727
    DE202408202727 over 9 years ago
    Check the values of your temp variables. Do you have write access to the folders that are specified?
  • Chise
    hi,the question "E- *Error* loadContext: could not open file - "64bit/AutosilkUtils_public.cxt",could you been solved?
  • Chise
    Chise over 8 years ago in reply to DE202408202727
    hi,when i use loadcontext to load .cxt files,it tells "E- *Error* loadContext: could not open file - "64bit/AutosilkUtils_public.cxt".could you tell me how to solve the problem?
  • DE202408202727
    It should work if you have the correct cxt file.
    See attached (it needs to be renamed to AutosilkUtils_public.cxt and placed in the 64bit folder in your SKill path
