  3. AutosilkUtils in 17.2
  • Replies 19
  • Subscribers 167
  • Views 26151
EvanShultz
EvanShultz over 10 years ago
I suspect eDave may be the best person to answer, but any feedback is welcome. After upgrading to 17.2 from 16.6, invoking Allegro shows the following error in the console:
E- *Error* loadContext: could not open file - "64bit/AutosilkUtils_public.cxt"
Is there an updated utility for 17.2? Perhaps I'm doing something wrong?
  • Chise
    Chise over 8 years ago in reply to EvanShultz +1
    hi,the question " E- *Error* loadContext: could not open file - "64bit/AutosilkUtils_public.cxt ",could you been solved?
  • DE202408202727
    DE202408202727 over 8 years ago in reply to Chise +1
    Is your question about AUtoSilkUtils or about creating context files in general?
  • Chise
    Chise over 8 years ago in reply to DE202408202727
    Sorry, eDave.I may not have described it clearly.
    i don not konwn how to create a new cxt file.I follow the instructions"setContext、load、defInitProce、saveContext" to create a context using il_allegro.exe.when i loadContext the Generated cxt file,it will tell me "E- *Error* loadContext: could not open file - "64bit/***.cxt".when i use the cdsmps in linux to create the cxt file,He also prompted the question "E- *Error* loadContext: could not open file - "64bit/***.cxt".
    when i use the  function "saveContext" in cdsmps.exe under windows to create the cxt file,it will Prompt "skilldev not enable"and connot create the cxt file.
    so I'm so upset I don't know how correctly to create the cxt file in allegro spb 17.2.I really hope to get your help.Looking forward to your reply.thanks!!!
  • DE202408202727
  • Chise
  • JamesLin
    JamesLin over 3 years ago in reply to DE202408202727
    y = y + 2, AFn_formGroup(p, "Use Silk Layers", x, y, 38, grpLen + 5); 4
    y = y + 1
    AFn_formChecklistItem(p, "usesilk", x + 2, y+2, "Auto suggested layer selection" ?radioLabel "chktype")
    y = y + 2, y1 = y
    (This code is modified from version 8.23. The Ver 8.23 skill. The 8.23 version of skill has the same display problem )
