  3. square shaped void with radius
  • Views 16813
masamasa
masamasa over 7 years ago
hello
how can i change a square shaped void on a shape to a void with a radius at 4 corners?
  • steve
    steve over 7 years ago
    Try Shape Edit Mode, set the value of the radius in the Options pane then hover over the corner and right click - Trim Corner
  • masamasa
    masamasa over 7 years ago in reply to steve
    thank you steve
    i was able to change the corners with radius.
    do i have change it one by one?
    is there any way i can change the radius at multiple corners with one click?
    is there any place that i can set up the radius of a shape as general parameters?
  • steve
    steve over 7 years ago in reply to masamasa
    Yes, hover over the edge then use the TAB key until you get Shape in the tooltip, then right click - Trim Corners and the radius is applied to all corners. For the radius before drawing only when you add a rectangular shape, look at the options pane and choose Place Rectangle and set the size of the rectangle and the corner you want
  • masamasa
    masamasa over 6 years ago in reply to steve
    thank you for your help as always, steve.
    is there a way to modify the radius on multiple shapes at once?
    i understand now how to modify the radius at all corners on one shape.
    but i have a few hundreds of square shapes that are needed to be modified.
    actually i have created a funckey but it works only on one shape at a time.
    funckey End "pop dyn_option_select '@:@Trim corners'; trim shape vertices"
    it does not work on multiple shapes.
  • steve
    steve over 6 years ago in reply to masamasa
    No it doesn't and there is no way to do this on multiple shapes at the same time. You can CTRL+ Select Multiple shapes but this limits the operations that can be done so you may have to do this individually.....
