  3. [OrCAD PCB] Undo history constantly disappears
  • Replies 8
  • Subscribers 166
  • Views 23303
Mysil B
Mysil B over 7 years ago
Hello
While working on our PCB designs, the undo history constantly clears out and we cannot undo changes recently made.
Play this video
It seems like every other command triggers this erasure, rendering the undo / redo functionality practically useless.
Is this a feature or bug?
  • Fredda
    Fredda over 5 years ago in reply to Mysil B +2
    ...and it will always be like this. At least no difference more than two years later. It really is a mystery why they ignore this basic function. Only thing I can think of is a huge flaw in the core of…
  • Mysil B
    Mysil B over 7 years ago +1
    So we contacted our channel partner, and they confirmed that running commands or tools that open up dialog windows will erase your history, and it's allways been like this. This would be considered a…
  • excellon1
    excellon1 over 7 years ago
    The undo history can be changed from its default to zero. Go to "Setup User Preferences' You should see a box called "search for preferences" In the box type undo and click the search button. You should see two items returned.
    Look at the Undo_depth and see if a value was assigned to it. If the box is empty then the default will be 10 commands of undo. It's possible someone may have set a 0 in the box ?
  • Mysil B
    Mysil B over 7 years ago in reply to excellon1
    Thanks for the reply, excellon1.
    The values are set to their limits. And this seems to work as long as we avoid half the functions and tools of OrCAD PCB.
  • excellon1
    excellon1 over 7 years ago in reply to Mysil B
    Have you tried setting the values to something else ?. Maybe set everything to the default values and see how that does. Both boxes no entry, leave them blank. What ver of the SW are you running ?
  • Mysil B
    Yeah, we've tried different values, but to no avail.
    Play this video
    We have the latest hotfix installed on our 17.2-2016 install.
  • excellon1
    Hi I'm thinking this may be a bug. Perhaps open a ticket with tech support and see what they say.
