  3. Export DXF.
  • Replies 28
  • Subscribers 166
  • Views 32841
Export DXF.
vimaldevlpr
vimaldevlpr over 7 years ago
Hai,
I don't  know how to export DXF for all the present layer by once itself  by using  File->Export->DXF we only take the present layer.  For another we need to change that layer and once again i want to do the same process in this case how to take all the layer by once itself  any one guide me please. if it possible by skill share me the code please.
  • Gowtham229
    Gowtham229 over 7 years ago
    hi what was your actual concern do you want to take all the layer in dxf at once
  • vimaldevlpr
    vimaldevlpr over 7 years ago in reply to Gowtham229
    Hai gowtham thanks for your reply it actually takes much time for taking again and again if it once means very easy  thats why if it possible can you please say how to do.
  • Gowtham229
    Gowtham229 over 7 years ago in reply to vimaldevlpr
    Hi vimal,
    i think its better to save color files with customized view path where you can always select view and immediately export dxf which will be very easy.or else you need a skill code to customize the layers export in dxf which i dont have yet
    Gowtham
  • vimaldevlpr
    Thank you gowtham
  • vimaldevlpr
    Hai here in the artwork number of layers present  by using this artwork is there a way to get .dxf file export using skill
    If it possible can you please guide me.
